Integra Passenger side axle
Im trying to take out the axle and the driver side slide out of the hub fine with the other end still in the trans but the passenger side wouldnt even budge.
Do i need to take the other end out of the trans first then take it out of the hub?
So pry the axle out of the trans then take the axle out of the hub? Having a lunch break and wanna make sure when i get out there, i get it done
Yep, loosen the castle nut on the spindle assembly to the LCA so the brake assembly can move around. Then pry it off the trans
It's easier IMO, there are other ways, like what you said but I prefer to get it loose off the trans before I pull it out if the hub completely.
I already remove the spindle nut and i can move the hub around freely but is the axle suppose to stuck onto the hub? the driver side it would it i use my finger to push it but the passenger side i hammer it once and it didnt even budge.
When i pry the part where it stick into the trans it seem like something inside is holding onto it
project91crxsi
Aug 21, 2009 05:56 PM
