Need help, Blown motor...
Old Aug 17, 2006 | 10:30 AM
escape2me's Avatar
Default Need help, Blown motor...
So i blew my motor with a dry shot of nitrous because there was no pill in the line when it was installed. I have a code of cylinder one and two misfire now, has anyone had any experience with blowing there motor and have any suggestions... I just had to pay 800.00 dollars for school and have no money for a shop to repair it... I dont have the tools at my house to pull an engine, i dont know what to do...
Old Aug 17, 2006 | 11:03 AM
Lan's Avatar
Lan
Default Re: Need help, Blown motor... (97 GSR)
Did you have it installed? Or did you install it? You may be able to have the installer pay for a new motor. Swapping an engine is easy. You can DIY but a complete swap is going to be $$$ if you are going to buy a complete GSR.
Nors's Avatar
If you just have 2 misfires thats not a blown engine. Do a compression test followed by a leak down test. You can probably get a comrpession tester at autozone or a similliar place.
Old Aug 17, 2006 | 11:05 AM
escape2me's Avatar
Default Re: (Nors)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nors &raquo;</TD></TR><TR><TD CLASS="quote">If you just have 2 misfires thats not a blown engine. Do a compression test followed by a leak down test. You can probably get a comrpession tester at autozone or a similliar place.</TD></TR></TABLE>Doesnt that require you to start the engine?
Old Aug 17, 2006 | 11:22 AM
Danziver's Avatar
Default Re: (97 GSR)
You just bump it with the tester screwed into the spark plug hole.
Old Aug 17, 2006 | 11:44 AM
Racermech's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97 GSR &raquo;</TD></TR><TR><TD CLASS="quote">Doesnt that require you to start the engine? </TD></TR></TABLE>
I am guessing by this comment then engine does not even run?
Old Aug 17, 2006 | 11:46 AM
escape2me's Avatar
Default Re: (Racermech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Racermech &raquo;</TD></TR><TR><TD CLASS="quote">
I am guessing by this comment then engine does not even run?</TD></TR></TABLE>No it runs... but i just dont want to further damage it... it warbles like a wrx... Im gonna pull the head to see if i can get anything from that...
Old Aug 17, 2006 | 01:13 PM
PLAGUED_DB7's Avatar
Pull the head and you will see what the damge is.
good luck
Old Aug 17, 2006 | 02:00 PM
stp_vtec_boi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97 GSR &raquo;</TD></TR><TR><TD CLASS="quote">So i blew my motor with a dry shot of nitrous because there was no pill in the line when it was installed. I have a code of cylinder one and two misfire now, has anyone had any experience with blowing there motor and have any suggestions... I just had to pay 800.00 dollars for school and have no money for a shop to repair it... I dont have the tools at my house to pull an engine, i dont know what to do...</TD></TR></TABLE>
How many shots did you shoot. 75 shot is a bit risky already cause i know from experience on my Ls.
Old Aug 17, 2006 | 03:37 PM
gamemaster000's Avatar
Wow. Running nitrous with a schetchy install, no $$ to back it up, and no way to recover if things get screwed up? Not smart bro.
Get a bus ticket and save up for a swap, if it's for sure blown. Sorry about your situation, but be smart about what you may be getting yourself into. Don't experiment on a car you depend on.
Old Aug 17, 2006 | 04:13 PM
escape2me's Avatar
Default Re: Need help, Blown motor... (gamemaster000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gamemaster000 &raquo;</TD></TR><TR><TD CLASS="quote">Wow. Running nitrous with a schetchy install, no $$ to back it up, and no way to recover if things get screwed up? Not smart bro.
Get a bus ticket and save up for a swap, if it's for sure blown. Sorry about your situation, but be smart about what you may be getting yourself into. Don't experiment on a car you depend on.</TD></TR></TABLE>This ive learned...
Old Aug 17, 2006 | 06:30 PM
Nors's Avatar
If it sounds like a WRX you probably spun a bearing or even threw a rod. can you tell if the noise is valvetrain or bottom end?
Old Aug 17, 2006 | 07:58 PM
gsr dood's Avatar
Default Re: (Nors)
im gunna put my money on a couple bent valves. cylinder mis fire is either gunna be a spark plug failure, clogged fuel lines, ignition timing off certain degrees or a valve is bent out of whack. considering you put nitrous through the engine, and it sounds like its hesitating an has a rumble, i DEF have money on a chipped or bent valve. pull the head and loook. im interested
Old Aug 18, 2006 | 09:43 AM
escape2me's Avatar
Default Re: (gsr dood)
Thanx... ill post the results
JustHere4ADay
Dec 10, 2007 08:15 AM
JustHere4ADay
10
Dec 8, 2007 11:13 PM
Rcp
Northern California (Sales)
Aug 10, 2007 10:11 PM
regime team
Honda S2000
Jun 15, 2006 08:22 PM
mousiex113
Feb 13, 2006 10:07 AM
