Suspension & Brakes Theory, alignment, spring rates....
upper front control arm question...
Old Aug 17, 2006 | 09:34 AM
divingcorners's Avatar
Default upper front control arm question...
i just put the D2 suspension on my EK and in the front, i'm getting some mad hard noises under certain bumps... i'm assuming that this is the front upper control arms hitting. IF this is the case, is my only solution raising the car?
Old Aug 17, 2006 | 10:00 AM
TunerN00b's Avatar
Default Re: upper front control arm question... (divingcorners)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by divingcorners &raquo;</TD></TR><TR><TD CLASS="quote">i just put the D2 suspension on my EK and in the front, i'm getting some mad hard noises under certain bumps... i'm assuming that this is the front upper control arms hitting. IF this is the case, is my only solution raising the car?</TD></TR></TABLE>
Pretty much. You can try stiffer springs, but you'll need to go quite a bit stiffer to reduce the impact noticeable.
deepee310
Jan 13, 2019 09:33 PM
4drgsr96
Oct 24, 2006 07:20 AM
Brown-tec
Apr 25, 2006 05:53 AM
speedworks
Oct 28, 2005 03:09 PM
