brake caliper grinding on rotor?
my 93 hatch's front brake calipar is grinding on my rotor. my first guess is a shot wheel bearing....what do you guys think? I haven't driven it in a few weeks but i recall i could turn (i think) right and it would not grind (not sure if that helps any) all other times it would grind/rub.
thanks
thanks
Ummm... might want to check your pads first... bearings make more of a low pitch groan or whirr at speed and get louder when turning....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miahmouse »</TD></TR><TR><TD CLASS="quote">Ummm... might want to check your pads first... bearings make more of a low pitch groan or whirr at speed and get louder when turning.... </TD></TR></TABLE>
That and also make sure that the caliper is tight on the bracket.
