HELP! experience technicians.
well i recently had a gsr swap into my ek hatch.
and numerous things are going wrong so im thinking about re-swapping it
the cluster doesn't work....transmission is bad....oil leaks...and gets hot very easy...
should i re-swap it with a nother wire harness and change the transmission?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK SQUAD 425 »</TD></TR><TR><TD CLASS="quote">well i recently had a gsr swap into my ek hatch.
should i re-swap it with a nother wire harness and change the transmission?</TD></TR></TABLE>
I think you answered your own question...
what get's hot?
Where does the oil leak?
oh wait i'm not an experience technicians, whatever that is..
what get's hot?
all of this is minor problems you might face when you swap a motor. it can all be easily fixed without having to reswap.
reswaping with the same technquie will not solve anything.
be more specific, how is it overheating? how is the tranny bad, where is it leaking from, etc...
xsuperxsonx
May 13, 2006 11:50 AM
