b16 swap axles and intermediate shaft problem PIC INSIDE!!
Old Aug 16, 2006 | 07:19 PM
ShagPower's Avatar
Default b16 swap axles and intermediate shaft problem PIC INSIDE!!
So I just bought a b16a2 swap for my 94 DX coupe. Everything seems to be in order except my confusion with these axles I got with it.
Now the guy gave me 2 different axles but it was my understanding you have one axle with two-male ends for the passenger side, and one with one-female/one-male end that connects to the intermediate shaft on the drivers side...or am I wrong...i've never done a swap nor played with the transaxle so this is something I honestly have no idea about.
i have these two below...so its looking like one is wrong, which one? and I'll need the intermediate shaft too right, what should i get it from (acura civic...??) Thanks!
Old Aug 16, 2006 | 07:25 PM
KtHaNxBai's Avatar
Default Re: b16 swap axles and intermediate shaft problem PIC INSIDE!! (ShagPower)
take them both to vatozone, and see for ur self, which one u need.
Old Aug 16, 2006 | 07:31 PM
savinGAShaulinAss's Avatar
Default Re: b16 swap axles and intermediate shaft problem PIC INSIDE!! (galaxykid70)
if i remember correctly 90-93 integras have 2 male ended axles with female intermidiate shaft(which it looks like u need)94+ integras have 1 male axle and the other one is a female+male combo with similar intermidiate shaft.
Old Aug 16, 2006 | 07:38 PM
ShagPower's Avatar
Default Re: b16 swap axles and intermediate shaft problem PIC INSIDE!! (savinGAShaulinAss)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by savinGAShaulinAss &raquo;</TD></TR><TR><TD CLASS="quote">if i remember correctly 90-93 integras have 2 male ended axles with female intermidiate shaft(which it looks like u need)94+ integras have 1 male axle and the other one is a female+male combo with similar intermidiate shaft. </TD></TR></TABLE>
so i have 90-93 axles?...will those even work with my car
anyone else??
Old Aug 16, 2006 | 07:45 PM
yup if u use the 90-93 intermidiate shaft with the axles in the pic then u should be golden just try to remember for future reference
Old Aug 16, 2006 | 07:56 PM
ShagPower's Avatar
im getting different answers for this when i search
This is for a HYDRO S4C (99-00 si) transmission by the way, not cable.
Old Aug 16, 2006 | 08:13 PM
well i went to autozone (where real racer go) and try to get a replacement for my 92 civic w/ a b swap and hydro tranny i asked for a 94 integra axle for the drivers side and it was male and female i then asked for a 93 axle and it was male.i then came home and searched and found out the info that i just gave u i cant remember the thread or if i smoked that blunt before or after the thread so all i can tell u is go to autozone and ull know first hand. good luck
Old Aug 16, 2006 | 08:16 PM
also hydro or cable it wont matter the intermidiate shaft will go on its a b series so its just a matter of finding the combo i said earlier
Old Aug 16, 2006 | 10:20 PM
qfast817's Avatar
what kind of intermedate shaft do you have male or female?
Old Aug 16, 2006 | 10:43 PM
TH33G4MON3's Avatar
Default Re: b16 swap axles and intermediate shaft problem PIC INSIDE!! (qfast817)
No you are right you need the female one... same thing happened to me when I did mine lol
Old Aug 17, 2006 | 11:37 AM
ShagPower's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by qfast817 &raquo;</TD></TR><TR><TD CLASS="quote">what kind of intermedate shaft do you have male or female?
dont have one as of yet. So its looking like I could either:
-get the male/female axle...and get the male ended intermediate shaft (from a 94+ integra)
or
-use the axles i have now and get the female ended intermediate shaft from a 90-93 teg
Old Aug 17, 2006 | 11:43 AM
philosofy1's Avatar
seems like you have 2 of the same axles. the rightside. i would just pick uo the correct ones the belong to that engine.
Old Aug 17, 2006 | 11:47 AM
ShagPower's Avatar
Default Re: b16 swap axles and intermediate shaft problem PIC INSIDE!! (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">seems like you have 2 of the same axles. the rightside. i would just pick uo the correct ones the belong to that engine.</TD></TR></TABLE>
by rightside do you mean drivers or passenger side
Old Aug 17, 2006 | 11:49 AM
philosofy1's Avatar
rightside = passenger side
leftside = driverside
Old Aug 17, 2006 | 11:51 AM
ShagPower's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">rightside = passenger side
leftside = driverside</TD></TR></TABLE>
thanks
i think i'll just get the 94+ axle and intermediate shaft, keep everything easy
Old Aug 17, 2006 | 11:53 AM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ShagPower &raquo;</TD></TR><TR><TD CLASS="quote">
thanks
i think i'll just get the 94+ axle and intermediate shaft, keep everything easy </TD></TR></TABLE>
jdm_vtec
Aug 30, 2007 11:57 AM
crex23
Oct 1, 2005 12:42 PM
crex23
Sep 29, 2005 08:34 AM
user 72830283
12
Sep 26, 2005 05:01 AM
