megan test pipe
Old Aug 16, 2006 | 06:46 PM
25Type-s's Avatar
Default megan test pipe
im a little dazed i was wondering how does the test pipe work where does it go and things like that pictures would br grate... thanx
Old Aug 16, 2006 | 09:50 PM
ScuDC5's Avatar
Search is your friend. Use it, learn it, love it.
But to give a short answer, the test pipe replaces the spot where your catalytic converter is, freeing up the exhaust flow.
Old Aug 17, 2006 | 12:12 PM
25Type-s's Avatar
Default Re: (ScuDC5)
thanx a lot for the info i yped in megan test pipe in the search but i found no pics but thanx anyway
i was also wondering if i get a reflash would that make my car go lean just like with a race header or no????? and one more thing what does it mean to go lean i hear it all the time and i feel like an *** for not knowing
Modified by 25Type-s at 1:32 PM 8/17/2006
Old Aug 17, 2006 | 05:24 PM
n7plus1's Avatar
Default Re: (25Type-s)
when more air is taken in than fuel. but your fine though...stock ecu recalibrates itself.
Old Aug 17, 2006 | 06:33 PM
25Type-s's Avatar
Default Re: (n7plus1)
what if i get a reflash would that make a differance???
Old Aug 22, 2006 | 04:16 AM
ScuDC5's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 25Type-s &raquo;</TD></TR><TR><TD CLASS="quote">what if i get a reflash would that make a differance???</TD></TR></TABLE>
You'll be fine, the reflash does not effect that. It adjusts things like cam angle, rev limiter, vtec points, not the a/f ratios.
Old Aug 22, 2006 | 06:51 AM
Miracle's Avatar
You will need a o2 simulator to eliminate a check engine light on a car with not cat. The test pipe bols in in place of the stock cat, increasing exhaust flow.
But I forewarn you, your car will sound like **** afterwards. Alot more rasp, and alot more noise.
Here is an o2 simulator for a Subaru, to give you an idea of what I am talking about.
One end of the connector plugs into the cars harness, and the other plugs into the sensor itself
Old Aug 22, 2006 | 07:06 AM
ebp_dc2's Avatar
u will probably run lean with a #4 reflash. There are cases of people running lean with an exhaust and a CAI. It won't be too lean. The test pipe replaces the cat, and you are going to need to run some sort of o2 simulator
http://www.audizine.com/forum/...50825
that is a great article on how to trick your ECU into thinking the second o2 sensor is working properly. Works like a charm!
Old Aug 22, 2006 | 11:56 AM
SFRSX's Avatar
Default Re: megan test pipe (25Type-s)
Sup Bro i have one on my car i really like it but something broke inside the test pipe and it's making a rattling noise and other than that it's pretty good for the price. I been trying to find out where i could get the o2 simulator no luck yet you will need it
Old Aug 22, 2006 | 01:16 PM
...me0w's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SFRSX &raquo;</TD></TR><TR><TD CLASS="quote">Sup Bro i have one on my car i really like it but something broke inside the test pipe and it's making a rattling noise and other than that it's pretty good for the price. I been trying to find out where i could get the o2 simulator no luck yet you will need it </TD></TR></TABLE>
i dont know if i would get a megan i picked one up from a buddy of mine for ten bucks and it had something rattling in it so he took it off his car and i finally got a huge chunk of carbon/resonator out of it........... i say save up the money and pick up a jackson racing header and test pipe...........
Old Aug 22, 2006 | 06:52 PM
25Type-s's Avatar
thanks a lot for all the input thats everything there is to know about the test pipe they should save threads like these for leater refrence.. peace
jdmisoverrated
Jan 31, 2008 07:54 AM
fjt
Nov 17, 2004 09:40 AM
SuicideSlide
10
Sep 23, 2004 05:58 AM
98Psi ITR
Dec 1, 2001 12:06 PM
