gsr tranny w ls 5th gear???
Old Apr 25, 2002 | 02:36 PM
chromedome's Avatar
Default gsr tranny w ls 5th gear???
anyone has a gsr tranny with ls 5th gear on a ls engine?? is this worth doing and possible.. what benefits other than faster revving engine or downfalls? curious as to how this would perform on a 93 integra ls with i/h/e/tb act clutch lightened stock flywheel. plan to stay n/a ..would a quaife atb diff make a big difference also in acceleration and handling??? any input would help ..
steve golea
xXx integra
Old Apr 25, 2002 | 06:54 PM
Rtzx9r's Avatar
GDD 1%
Default Re: gsr tranny w ls 5th gear??? (chromedome)
You're treading on thin ice my friend. I have tried this topic of gsr trannies and all the gsr owners say that it makes no difference. Just a word of caution!
Old Apr 25, 2002 | 07:04 PM
chromedome's Avatar
why would it make no difference? would'nt the shorter gearing on the gsr tranny work better on an n/a ls engine and the ls 5th gear be better for freeway cruising?????anyone know any better???
steve g
xXx integra
Old Apr 25, 2002 | 07:09 PM
Dirty GS-R's Avatar
New User
It'll definitely improve your acceleration. I wouldn't bother with the LS 5th though.
Old Apr 25, 2002 | 07:22 PM
chromedome's Avatar
Default Re: gsr tranny w ls 5th gear??? (2K1 GS-R)
would'nt the gsr tranny cause my 5th gear rpm's to be too high for freeway cruising around 70-80 mph, that's why i would need to use the ls 5th gear in the gsr trannyto keep the cruising rpm's around 3700 rpm at 75-80 mphon the freeway.
steve g
xXx integra
Old Apr 25, 2002 | 07:28 PM
mattL's Avatar
the gsr 5th is pretty nice, i'm at 3500 when going 70 and 4000 when going 80, what you do want to do is get an SI or ITR tranny and throw the 5th gear on it cause they suck for highway.
Old Apr 25, 2002 | 07:31 PM
Dirty GS-R's Avatar
New User
Default Re: gsr tranny w ls 5th gear??? (mattL)
I love my ITR tranny. Nothing like cruising at 4500rpm on the highway.
Old Apr 25, 2002 | 07:40 PM
Rob Dizzle's Avatar
https://honda-tech.com/zerothread?id=161514
I had a big replys happening on that one
i was going for diff reasons. im thinking of getting a lower final drive ratio (ats possibly)
if you have an aftermarket exhaust cruising @ 80 on the freeway is still kinda loud. would prefer for it to be lower
Old Apr 25, 2002 | 07:48 PM
threatcon13's Avatar
New User
Default Re: gsr tranny w ls 5th gear??? (bob46802)
the ideal setup for N/A would be a jdm type R tranny w/ GSR 5th....GSR 5th is fine for freeway cruising...the type R tranny would shorten all your gears. add a jdm final drive in there and you'll be set.
Old Apr 25, 2002 | 07:52 PM
Dirty GS-R's Avatar
New User
Default Re: gsr tranny w ls 5th gear??? (ALLMOTORDC2)
That wont do much considering that the 98+ spec JDM ITR tranny shares the same 4th and 5th gear ratios as the GSR.
Good luck trying to find a 96-97 spec JDM tranny.
[Modified by 2K1 GS-R, 11:57 PM 4/25/2002]
Old Apr 29, 2002 | 09:21 AM
RC211V's Avatar
if im at 4,500rpm i am at 90mph
dannyhoo
Transmission & Drivetrain
Jul 7, 2015 12:48 PM
egdriver90
Sep 13, 2009 12:40 AM
Rain n Blood
Aug 18, 2004 04:51 PM
Jonathan_ED3
Apr 19, 2002 12:06 AM
Allstar
Oct 24, 2001 09:41 PM
