B16 4.4 and ITR 4.7 FD fit Ls trannys?
the b16a and the ls share the same ring gear bolt patten so you will be able to sue what ever b16a ring gear in ls. 4.4 vs 4.2 ls
From: gravity rides everything...everything will fall, se GA/ne FL
for a 4.40 into your LS, use a output shaft and ring gear from a b16.
for a 4.78, use the 4.78 output shaft and ring gear and a itr/gsr od. differential.
b18bEKcoupe
Jun 28, 2007 11:18 PM
