fuel presure= free hp
Old Aug 16, 2006 | 12:01 PM
raphael's Avatar
Default fuel presure= free hp
ive searched and i couldnt find it. is it possible to adjust the fuel pressure to make horsepower in the high rpm range? this is a general question on any motor
Old Aug 16, 2006 | 12:04 PM
spoonek9's Avatar
Default Re: fuel presure= free hp (raphael)
Not if the engine is already properly tuned, adding or subtracting fuel may lead to a decrease in performance.
Old Aug 16, 2006 | 06:37 PM
atg1290's Avatar
If your just dumping fuel in wouldnt it cause it to run rich??
Old Aug 16, 2006 | 07:06 PM
Scott_Tucker's Avatar
Your signature tells the whole story. Nothings free.
Old Aug 16, 2006 | 08:45 PM
raphael's Avatar
so if i added a aftermarket fuel rail i wouldnt gain anything instead i would run shity rite?i was thinking that maybe at higher rpms the motor needs more fuel so a little extra work on a better fuel system on an all motor platform would add power
Old Aug 17, 2006 | 03:44 AM
Enzo Speed's Avatar
Default Re: (raphael)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raphael &raquo;</TD></TR><TR><TD CLASS="quote">so if i added a aftermarket fuel rail i wouldnt gain anything </TD></TR></TABLE>
Correct. Nothing would change.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">instead i would run shity rite?</TD></TR></TABLE>
No, it would run the same. Adding an aftermarket rail doesn't change anything.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">i was thinking that maybe at higher rpms the motor needs more fuel so a little extra work on a better fuel system on an all motor platform would add power</TD></TR></TABLE>
1. The first step in getting more fuel to the motor is to upgrade your injectors. Leave the other fuel components alone.
2. Modifying/changing/upgrading the fuel system doesn't add power. It doesn't do anything other than allow you to to flow more fuel, if need be. A car is like a computer - there's hardware and software. You can't just throw on a bunch of new hardware and expext it do anything when you haven't installed the corresponding software. Well, it's the same for your car. You can modify whatever you want, but you need the appropriate tuning software to make it work.
rewerbcrx
Oct 19, 2005 08:31 AM
SiShane
Jun 8, 2004 02:56 PM
tgod1020
Sep 25, 2003 12:05 AM
mrcrimane
Aug 9, 2003 11:43 AM
digitalspice
Dec 18, 2001 07:57 AM
