rough idle--vacumme??
Old Aug 16, 2006 | 11:26 AM
gsxr1k05's Avatar
Default rough idle--vacumme??
i did the rear disc swap on my 90 crx dx, adn use the 94 teg back end. then i did the master cyclinder/booster swap with a 1" from a 94 teg and used the 40/40 prop valve. now i have a rough idle. it does nto stall or cut out, i am just wondering is this from the increase in vacumme from the large booster? the auto tranny seems to shift better as well. any ideas? comments/suggestions?? thanks. i will post pics when i get back from ntc ft. irwin cali on 15th sep
Old Aug 16, 2006 | 11:37 AM
gsxr1k05's Avatar
Default Re: rough idle--vacumme?? (gsxr1k05)
bump.. i would love an answer for this.. i am just curious about why it does it.
Old Aug 16, 2006 | 12:25 PM
thesmogman's Avatar
Check your check valve. On it there is an arrow that points toward the engine side of the vacuum line. If you have it wrong it can mess with the idle.
Also check to see if the booster will hold a vacuum. It might be leaking.
Old Aug 16, 2006 | 01:57 PM
gsxr1k05's Avatar
Default Re: rough idle--vacumme?? (thesmogman)
how do you check the booster to see if its leaking.
weaslehunter1
Jan 26, 2015 03:49 PM
Tarlacon
Mar 22, 2008 07:48 AM
92integraVTECgsr
Nov 12, 2005 12:29 AM
rudeman85
Jun 16, 2005 09:48 AM
cifer6425
May 19, 2004 10:00 AM
