which clutch do i get
Old Aug 16, 2006 | 09:39 AM
whiteb16's Avatar
Default which clutch do i get
i have a jdm b16a. i cant figure out what kind of car it came out of but i went to buy a clutch and the clutch for a 99 civic si and 95 del sol do not fit. how can i figure out what clutch will match?
Old Aug 16, 2006 | 09:47 AM
Bense's Avatar
Default Re: which clutch do i get (whiteb16)
cable or hydro
Old Aug 16, 2006 | 09:58 AM
whiteb16's Avatar
Default Re: which clutch do i get (Bense)
hydro
Old Aug 16, 2006 | 10:16 AM
kr's Avatar
kr
i would choose an Exedy Cluth stage I.
Old Aug 16, 2006 | 10:20 AM
Bense's Avatar
how does it not fit?
doesn't fit on inputshaft
doesn't fit on flywheel
pressure plate doesn't align with flywheel studs/threads
Old Aug 16, 2006 | 10:36 AM
WONG FRIED RICE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whiteb16 &raquo;</TD></TR><TR><TD CLASS="quote">i have a jdm b16a. i cant figure out what kind of car it came out of but i went to buy a clutch and the clutch for a 99 civic si and 95 del sol do not fit. how can i figure out what clutch will match?</TD></TR></TABLE>
which ever transmission you have... get the clutch for that one.
Old Aug 16, 2006 | 10:40 AM
Vt3c_eg's Avatar
you need a hydro b-series clutch. anything that says b-series should fit.
Old Aug 16, 2006 | 12:06 PM
whiteb16's Avatar
Default Re: (Bense)
it is bigger than the original one. only by a very little bit but bigger. the bolts dont line up on the flywheel.
Old Aug 16, 2006 | 12:07 PM
whiteb16's Avatar
Default Re: which clutch do i get (Vt3c_eg)
i got a b16 clutch but its too big.
Old Aug 16, 2006 | 12:40 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whiteb16 &raquo;</TD></TR><TR><TD CLASS="quote">i got a b16 clutch but its too big.</TD></TR></TABLE>
maybe your not doing something right? any b-series clutch, flywheel, and tranny are interchangable.
maybe where you got the 2 clutches, they gave you the wrong one?
and when you say they don't fit, have you seen it yourself or are you going off of what someone has told you. i know for a fact the jdm B16A's found in the SIR & SIR2 (civic's from 89-95) are the same as the 94-95 (USDM) del sol. with minor differences of coarse (the clutch is not one of them).
Old Aug 16, 2006 | 02:13 PM
whiteb16's Avatar
Default Re: which clutch do i get (philosofy1)
i lined up the new clutch with the old flywheel and they don't go together. the clutch needs to be a little smaller. the clutch i ordered was from a 99 civic si. i am putting it on a b16a
Old Aug 16, 2006 | 03:14 PM
the clutch can only go on one way...u have to clock it so that all the holes line up
Old Aug 16, 2006 | 08:09 PM
whiteb16's Avatar
Default Re: which clutch do i get (WONG FRIED RICE)
i understand that. the new clutch and the old clutch are different sizes. they are both supposed to be for a b series engine but they are two different clutches.
Old Aug 17, 2006 | 09:29 AM
whiteb16's Avatar
he he. i found out i ordered the right clutch and they boxed it wrong. the one that was in the box didn't belong there. thanks for all the help.
Old Aug 18, 2006 | 12:29 AM
littlegreenb18's Avatar
idiot...
Old Aug 18, 2006 | 12:36 AM
Kamin's Avatar
Default Re: which clutch do i get (littlegreenb18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by littlegreenb18 &raquo;</TD></TR><TR><TD CLASS="quote">idiot... </TD></TR></TABLE>
shut up asshat
it happens all the time. dont be a dick
Old Aug 18, 2006 | 12:44 AM
Default Re: which clutch do i get (Kamin)
maybe i wouldn't be a dick if whiteb16 wouldn't be an idiot...
Old Aug 18, 2006 | 05:16 AM
sohc1200cc's Avatar
why not use the clutch of the 1st gen honda crv.. it will fit your b16 and will give a bigger friction surface.. a better bang for the buck!!
Old Aug 18, 2006 | 05:42 AM
si0385.'s Avatar
remember this kids name in case he ever has a problem with anything...
Old Aug 18, 2006 | 07:38 AM
Kamin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by littlegreenb18 &raquo;</TD></TR><TR><TD CLASS="quote">maybe i wouldn't be a dick if whiteb16 wouldn't be an idiot... </TD></TR></TABLE>
oh excuse me
im sure you fell out of the womb knowing everything.
nobody knows everything, some day you will need help too you *****.
Old Aug 18, 2006 | 11:36 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin &raquo;</TD></TR><TR><TD CLASS="quote"> nobody knows everything, some day you will need help too you *****. </TD></TR></TABLE>
That may be true, but i'm about as close as you can get. And if do ever need help, at least I'll remember not to listen to anything whiteb16 has to say, because he's an idiot.
Old Aug 18, 2006 | 11:42 AM
someone lock this thread so this numbnut can't post anymore ridiculous things.
Old Aug 18, 2006 | 11:49 AM
I'm not posting anything rediculous. just stating a fact, you are the one posting rediculous things, my nuts are not numb, and i don't appriciate you refering to my body parts anyway
Old Aug 18, 2006 | 11:55 AM
philosofy1's Avatar
i see all of your's points, and i understand your fustration (littlegreenb18).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whiteb16 &raquo;</TD></TR><TR><TD CLASS="quote">i understand that. the new clutch and the old clutch are different sizes. they are both supposed to be for a b series engine but they are two different clutches.</TD></TR></TABLE>
everyone is giving him the right answer but he's to stubborn to listen. in times like this you just have to ignore them. can't we all get along?
Old Aug 18, 2006 | 12:05 PM
.Grimace's Avatar
footwork mastery
just leave him a thumbs down in his for sale thread thats in his sig...
