Possibly a Fool's Dream
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97RSTEG »</TD></TR><TR><TD CLASS="quote">Is it dumb to think that I can get 200whp with a turbo on a LS (w/135000 miles) with out rebuilding the engine's internals?</TD></TR></TABLE>
yes...yes it is...you can get more
Do you guys have any suggestions as to if I should buy the turbo as a kit ,or piece by piece?
p.s. If piece by piece does anyone have a complete list concerning parts?
it is not a dream, it can be a reality. easy bro. i'm about to sell my turbo kit if you're interested...i'm just up in seattle. you'll just have to get a tune.
and there's a few good tuners down in portland area.
http://hondamarketplace.com/zerothread?id=1723372
and there's a few good tuners down in portland area.http://hondamarketplace.com/zerothread?id=1723372
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThatsTheTruth »</TD></TR><TR><TD CLASS="quote">not at all a dream bro, easliy attainable boosted</TD></TR></TABLE>
you should definitley be able to do that on stock internals ... anywhere from 7 to 10 psi should be safe without building the motor, and that should definitley get you to at least 200 whp ... check your compression ... remember, the lower your compression, the more boost you can safely run ... and most of all ... there are alot of very knowledgeable people on this site ... listen to what they have to say
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 518_GSR_kid »</TD></TR><TR><TD CLASS="quote">anywhere from 7 to 10 psi should be safe without building the motor</TD></TR></TABLE>
Here we go with the magical psi number again. 7-10 psi on a T3 is a lot different than 7-10 psi on a GT40.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 518_GSR_kid »</TD></TR><TR><TD CLASS="quote">remember, the lower your compression, the more boost you can safely run</TD></TR></TABLE>
No it doesn't. It just allows a larger margin for error when tuning the car on pump gas. You can run 12:1 on a boosted setup provided you have proper tuning for the octane of fuel you plan on running...but don't expect to be running anything lower in octane than race fuel.
correct, proper tuning is the key. BUT, you do tune for the boost level. so it's kindof hand and hand. but some people even boost 13psi on stock internals, no problem
dumpedeg818
Jan 5, 2010 04:22 PM
