clutch/tranny/crankshaft problem..
Old Apr 25, 2002 | 01:02 PM
Hung's Avatar
Default clutch/tranny/crankshaft problem..
My friend's car makes this very loud *clak* *clak* *clak* ( sounds like metal) right near the tranny. Every time he revs in neutral, the noise comes ( no noise at idle). But when the clutch is depressed and he revs the engine, no noise what-so-ever. I believe it's either a crank or clutch problem. Any ideas and suggestions?
Thanks,
Hung
Oh yea, it's got a Center Force stage 3 clutch installed about 7K miles ago.
Old Apr 25, 2002 | 11:47 PM
Jaker's Avatar
Default Re: clutch/tranny/crankshaft problem.. (Hung)
Input shaft bearing! The only way to change it is to strip down the tranny. Big job, $25 part.
Old Apr 28, 2002 | 03:57 AM
Rocket's Avatar
Default Re: clutch/tranny/crankshaft problem.. (Jaker)
You'll probably need a new clutch since it will have oil on it. Clak Clak... I guess that is the sound of a very ill tranny.
Old Apr 28, 2002 | 06:17 AM
SiR Kid's Avatar
New User
Default Re: clutch/tranny/crankshaft problem.. (Rocket)
I'd try a throw out bearing first.. sounds like a might be on that one... It's the bearing on the input shaft that makes the clutch work or not.
RG400SmartTowel
Oct 19, 2009 08:27 PM
aznsins88
Sep 17, 2004 02:42 PM
AzntaggeR
Mar 13, 2003 03:18 AM
91HATCH
11
Jan 14, 2002 06:47 PM
