Best Water Pump
Old Aug 16, 2006 | 04:53 AM
200cs's Avatar
Default Best Water Pump
for the reason of trying to get my car running cooler, I am going to change the water pump as it has 100k on it but looked fine when the belt was changed.
Does anyone make a good aftermarket pump that outperforms the stock one? Or would I be better off going back with an OEM pump. I am a little hesitant to use an Auto Zone or something like that.
Thanks in advance for your help.
Old Aug 16, 2006 | 05:57 AM
ITR-00-1457's Avatar
Default Re: Best Water Pump (200cs)
Your best bet is to go with an OEM unit, but if you want to get real crazy you can go with the Mezier electric unit.
Old Aug 16, 2006 | 06:10 AM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: Best Water Pump (ITR-00-1457)
Honda OEM!!!!
Old Aug 16, 2006 | 06:24 AM
200cs's Avatar
Default Re: Best Water Pump (walker111)
probably the way I am going to go just for peace of mind.....
I was thinking maybe someone made a bigger, better, faster version like you can get for old school hot-rods and such.....looks like not!
Old Aug 16, 2006 | 06:26 AM
RTW DC2R's Avatar
get a better radiator and/or different thermostat if you want it to run cooler. dont get too cool though because the ECU will think the car isnt fully warmed up and will stay in warm up mode.
Old Aug 16, 2006 | 06:52 AM
iperez's Avatar
Reliability = OEM
Better performance = Meziere
I have a Meziere pump on my daily-driven ITR. I've had it for over two years and it works great. As long as you don't put any weird additives in your coolant/antifreeze you will be fine. The electric pump cools A LOT better than OEM. I had to drill a few holes in my thermostat to make the car's temp reach normal operating temp to avoid having the car in warm-up mode. Its a good piece of hardware.
speedciv
May 24, 2016 11:51 AM
lostforawhile
May 9, 2013 06:54 PM
IntegraTypeR
Aug 3, 2007 08:18 AM
choiboiracing
Sep 28, 2005 07:24 AM
mingbling
10
Aug 6, 2004 08:39 AM
