what to build f22 or f23
Old Aug 16, 2006 | 04:13 AM
luder2_2vtec97's Avatar
Default what to build f22 or f23
I have a del sol with an f23. The motor just blew and I found an f22 in a 93 ex. I am trying to find out if you have to sleeve the f22 to forge it. I have a turbo kit ready and the only other plan I have at the moment is to take out the ballencer shaft. I guess the other question would be has any one ever took out there balancer shafts. Any other info on the f22 would help.
Old Aug 16, 2006 | 05:53 AM
notoriousB's Avatar
Default Re: what to build f22 or f23 (luder2_2vtec97)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by luder2_2vtec97 &raquo;</TD></TR><TR><TD CLASS="quote">I am trying to find out if you have to sleeve the f22 to forge it.</TD></TR></TABLE>
no you do not.
Old Aug 16, 2006 | 06:42 AM
sportyaccordy's Avatar
Default Re: what to build f22 or f23 (notoriousB)
OMGGGG go with the F22 definitely...get H22 pistons, an H23 intake manifold, a Delta 272 cam, a DC Sports header w/a 2.5" collector and exhaust...tune it...H22 power, K24 torque, probably a low 14 or high 13 sec. pull in your car.
Old Aug 16, 2006 | 12:47 PM
I am going boost. I thought all f and h series had to be sleeved
Old Aug 16, 2006 | 02:19 PM
pos_cd5's Avatar
Default Re: (luder2_2vtec97)
the F22 can withstand low-medium boost on a stock bottom end depending on your set-up and tuning
Old Aug 16, 2006 | 03:28 PM
Default Re: (pos_cd5)
Tuning is key. The block is strong. I'd get new pistons if for nothing else than to have stronger ringlands as that seems to be the only weak point in the motor under boost.
NA is more fun though.
Old Aug 17, 2006 | 03:09 AM
Thanks for the help I thought I could run h22 pistons. what bore size do I need.
Old Aug 17, 2006 | 03:13 AM
iam7head's Avatar
Default Re: what to build f22 or f23 (sportyaccordy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sportyaccordy &raquo;</TD></TR><TR><TD CLASS="quote">OMGGGG go with the F22 definitely...get H22 pistons, an H23 intake manifold, a Delta 272 cam, a DC Sports header w/a 2.5" collector and exhaust...tune it...H22 power, K24 torque, probably a low 14 or high 13 sec. pull in your car. </TD></TR></TABLE>
he/she is running a turbo, where exactly do you want the useless dc header?
why go with oem part tho? h22 will not be strong if you are boosting the damn thing, just go aftermarket once and for all.
Old Aug 17, 2006 | 06:46 AM
notoriousB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by luder2_2vtec97 &raquo;</TD></TR><TR><TD CLASS="quote">I thought all f and h series had to be sleeved</TD></TR></TABLE>
no just the H with the FRM sleeves.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sportyaccordy &raquo;</TD></TR><TR><TD CLASS="quote">NA is more fun though. </TD></TR></TABLE>
keep telling yourself that.
Old Aug 17, 2006 | 07:36 AM
gianinline's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sportyaccordy &raquo;</TD></TR><TR><TD CLASS="quote"> Delta 272 cam, a </TD></TR></TABLE>
What's up with that cam? How good is it? What kind of power and numbers can it give?
Thanks for any answers!
Old Aug 17, 2006 | 12:59 PM
I am trying to use aftermarket h22 pistons but I need a bore size to order
Old Aug 17, 2006 | 04:31 PM
luder2_...just get stock bore 8:1 H22 pistons...you don't have to resleeve for them, just a good hone.
gianinline...I will find out either this or next weekend I've heard nothing but good things other than a shitty idle and worse gas mileage.
Old Aug 18, 2006 | 06:26 AM
notoriousB's Avatar
Default Re: (sportyaccordy)
8:1? lord that's pretty low. I thought my 8.5:1 was low!
with H22 pistons what rods are you planning to use? why not just buy low C/R pistons designed for the F already?
Old Aug 19, 2006 | 04:53 AM
ther is none made and h22 rods
Old Aug 19, 2006 | 11:33 AM
-RedneckDave-'s Avatar
Working
Default Re: (notoriousB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by notoriousB &raquo;</TD></TR><TR><TD CLASS="quote">
No you can run Mahle pistons and you will be fine, and I would only sleeve an h series if the walls were scored.
Old Aug 20, 2006 | 05:08 AM
yeah I heard bad reviews about mahle
HaNsElBaDaSs
Aug 24, 2006 06:26 PM
ECX
Jul 31, 2006 10:23 AM
sohc prelude
Feb 21, 2006 12:04 PM
preludeguy06
Sep 10, 2005 04:54 PM
blake
Sep 27, 2003 02:45 PM
