VSS wiring colors, would love some help.
I'm swapping engines in my '93 EX and the pins popped out of my VSS plug. I cut the pigtail off of a '90 Accord EX parts car I had, the plug matches, but wiring colors do not. I need to know what color wire goes into each pin on the VSS plug.
Yes, I have searched. Thanks in advance.
The wires on the car harness are black, yellow/blue, yellow/white
The wires do the following work:
Yellow/Blue - 12v in Run or Start
Black - ground at thermostat housing
Yellow/White - speed signal to gauges, cruise and ECU.
What you need to do is figure out which wires do what on the accord VSS clip and then mate them to the wiring harness on your civic
Attoir
Aug 15, 2006 11:11 PM
CivicVX94
10
Apr 22, 2006 11:09 AM
