where can i find a hole in the fireall
Old Aug 15, 2006 | 07:33 PM
rollercosta123's Avatar
Default where can i find a hole in the fireall
i have a 97 and need to put wire through the firewall. i cant get anything through the hole on the driver side which is underneath the clutch master cylinder which makes no room at all but is there anywhere else i can put it thruogh????
Old Aug 15, 2006 | 07:41 PM
thatasiankidtony's Avatar
I had the same problem, but I fed the wire across the top of my engine bay zip tied it, and used a Socket Extention and fed the wire through the firewall under the power steering i believe, if you can't find it i'll take pictures. Once you get the wire through it's pretty easy to see the wire under the dash.
Old Aug 15, 2006 | 08:17 PM
c0ke's Avatar
Default Re: (thatasiankidtony)
I just installed my subwoofer/amp today. I ran the wire right below the glovebox. There's 2 holes through the firewall there, stuffed with rubber of course.
Old Aug 15, 2006 | 08:46 PM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: (c0ke)
You can easily remove the "grommet" holding the cable for cruise control and run the wire through there
Old Aug 16, 2006 | 07:02 AM
Default Re: (213374U)
thanks
Old Aug 16, 2006 | 11:16 AM
bps2799's Avatar
Default Re: (rollercosta123)
Don't remove it, just cut away a small portion of it and use a coat hanger to pull your wire through.
Old Aug 16, 2006 | 12:30 PM
TheMuffinMan's Avatar
He knows where you live!
There's one on the left side on the inside of the fender well plastic, it'll spit it out about 5 inches above the fuse box. Run the wiring above the plastic lining and then zip tie it up with the rest of the cables and pull it through
jvr
Apr 11, 2014 11:56 PM
Dekorum
14
May 6, 2011 11:17 AM
01em2man
Honda Civic (2001 - 2005)
Nov 4, 2006 10:10 AM
buzzsawstan
Jun 30, 2004 09:09 PM
redteg1
Audio / Security / Video
Mar 20, 2002 08:47 PM
