how do u take off a stud bolt?
Old Aug 15, 2006 | 07:31 PM
vermilion's Avatar
Default how do u take off a stud bolt?
i need serious help... how can you get a stud bolt from the brake caliper off?? this has got me stumpped.
Old Aug 15, 2006 | 07:32 PM
vermilion's Avatar
Default Re: how do u take off a stud bolt? (vermilion)
off of a 2002 ep3
Old Aug 15, 2006 | 08:01 PM
Miracle's Avatar
Are you talking about the caliper mount bolt, where the mount bracket bolts up to the knuckle, or the one from the caliper to its bracket?
What number is it in this picture?
#15 is the bolts that hold the caliper to its bracket. It is on the back side of the caliper.
#19 is the bracket to knuckle bolt
Surely you arent talking about the wheel stud itself, that holds the tire on. #20.
Old Aug 15, 2006 | 09:24 PM
vermilion's Avatar
Default Re: how do u take off a stud bolt? (Red_EM2)
the one that holds the rim tight with a lug nut
Old Aug 15, 2006 | 09:26 PM
vermilion's Avatar
well i just found out that what holds the bolt in places is compressed in (number 6).. thnx for the help.. that map really helps
Old Aug 15, 2006 | 09:27 PM
vermilion's Avatar
yeah i was talking about number 20.. that things a b**** to get off
Old Aug 16, 2006 | 01:29 AM
Miracle's Avatar
Yeah it is. It isnt advisable to beat and bang on it with a hanner.
You will need to use whats called a wheel stud clamp to get it off with. I will try and see if I cant come up with a photo. Its got prongs on one side, king of like a balljoint/ tie rod seperator, and a cupped pusher for the clamp to push the stud out with.
Old Aug 17, 2006 | 05:37 PM
salomon88's Avatar
you could try and get 2 nuts that will fit on the stud and put the first one 3/4 down the stung and the second tightly up against it and with a wrench on the back nut spin the stud out
Old Aug 17, 2006 | 08:35 PM
Miracle's Avatar
Default Re: (salomon88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by salomon88 &raquo;</TD></TR><TR><TD CLASS="quote">you could try and get 2 nuts that will fit on the stud and put the first one 3/4 down the stung and the second tightly up against it and with a wrench on the back nut spin the stud out</TD></TR></TABLE>
The stud isn't screwed into the hub, it is pressed.
The stud has splines around the outside part of the bottom of the stud. If you try that, and spin it out of the hub, you will only wallow out the bore in the hub. Then, you wont be able to replace the new one.
See what it is I'm talking about?
RSD765
Jun 17, 2010 11:30 AM
117
16
Apr 2, 2009 10:18 PM
gursh d
Sep 15, 2007 02:58 PM
lude98SH
Dec 7, 2006 10:24 PM
delsolnewkid
Mar 11, 2006 04:12 PM
