Suspension & Brakes Theory, alignment, spring rates....
Alignment results ... fixing caster?
Old Aug 15, 2006 | 07:10 PM
DHutch's Avatar
Default Alignment results ... fixing caster?
Ok so i just had an alignment done on my 97 gsr today ... the front passenger wheel was slightly off in all three dimmensions, due to a minor incedent where i slid sideways off of a 3" shoulder ... here are the results ... the toe was way off, but he obviously corrected that w/ tie rods etc. ... the camber is about a degree more positive than normal, and the castor between 0 and 1 degree more negative than normal ... the mechanic said it would be fine to drive on now that the toe is corrected, but recommended getting a kit to fix the camber/castor issue sometime in the near future ... right now my car has all stock suspension components, however this fall im looking to get new suspension (kyb agx w/ either h&r sport or race) ... fortunatley, i am already planning on getting a camber kit ... but my question is, is there a kit that can provide both camber and minor castor adjustment? ... if so who makes one? ... or am i better off finding out what is bent to cause the negative castor and replace it? ... any feedback is appreciated ... also ... the handling feels fine when i drive the car, it tracks perfectly straight, and although i have not done any hard cornering, it feels just like it always has ... any help will be greatly appreciated ... thanks!
Old Aug 15, 2006 | 10:09 PM
Tyson's Avatar
Default Re: Alignment results ... fixing caster? (518_GSR_kid)
instead of getting some kit, you should figure out which suspension component(s) is bent and replace it.
Old Aug 16, 2006 | 07:19 AM
DHutch's Avatar
Default Re: Alignment results ... fixing caster? (Tyson)
thanks for the feedback ... do you have any idea which parts commonly cause this castor problem when they bend/fail? LCA? frame?
Old Aug 16, 2006 | 08:39 AM
suspendedHatch's Avatar
Usually the LCA or the subframe.
Old Aug 16, 2006 | 08:20 PM
DHutch's Avatar
Default Re: Alignment results ... fixing caster? (suspendedHatch)
ok thanks i'll be looking into this ...
Old Aug 16, 2006 | 09:46 PM
dspIS-250's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">instead of getting some kit, you should figure out which suspension component(s) is bent and replace it.</TD></TR></TABLE>
no need for aftermarket alignment kit on stock suspension.
mrchevez
Aug 17, 2011 12:19 PM
TrueJimmy26
Suspension & Brakes
Jul 1, 2008 09:08 AM
dom93hatch
Apr 19, 2003 10:26 PM
Wai
Jan 2, 2002 09:08 AM
5-SpeedFreak
Nov 1, 2001 09:17 AM
