What could of cause this??
Old Aug 15, 2006 | 06:30 PM
ITR-2001's Avatar
Default What could of cause this??
Anyways the shaving that came of the flywheel is melted right onto the crank
Modified by ITR-2001 at 10:35 PM 5/2/2008
Old Aug 15, 2006 | 06:54 PM
NJIN BUILDR's Avatar
Default Re: What could of cause this?? (ITR-2001)
The flywheel bolts were not torqued properly or the flywheel was not seated against the crank properly when they were torqued.The crank and the flywheel were rubbing against each other.
Old Aug 15, 2006 | 07:26 PM
dunkd's Avatar
yup, you didnt torque down those flywheel bolts right.
ITR-2001's Avatar
Default Re: What could of cause this?? (NJIN BUILDR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">The flywheel bolts were not torqued properly or the flywheel was not seated against the crank properly when they were torqued.The crank and the flywheel were rubbing against each other.</TD></TR></TABLE>
This is the flywheel that came from the acura dealer ship when it was first bought...The tranny never came off until yesterday when I was changing it out with new a clutch/flywheel combo...Which is why that is not possible or maybe the car was not torque to spec when it came out of the factory?
Old Aug 15, 2006 | 07:28 PM
ITR-2001's Avatar
Old Aug 16, 2006 | 04:21 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR-2001 &raquo;</TD></TR><TR><TD CLASS="quote">
...Which is why that is not possible or maybe the car was not torque to spec when it came out of the factory?</TD></TR></TABLE>
OK,it was not properly assembled and torqued at the factory,it is possible.Same result.
Old Aug 16, 2006 | 06:50 AM
86si's Avatar
i have seen a clutch get so hot it almost welded itself to the crank. this was on a stock H22. looks like that may have happened. was the clutch really smoked.
Old Aug 16, 2006 | 10:00 AM
d16dcoe45's Avatar
Default Re: What could of cause this?? (86si)
Looks like the flywheel and crank friction welded themselves together!! Possibly bolts that started loosening or clutch slipping at high rpm = too much heat.
Old Aug 16, 2006 | 02:02 PM
ITR-2001's Avatar
Modified by ITR-2001 at 12:13 AM 4/3/2008
xduB95preludeSi
Sep 9, 2016 06:37 AM
MadCityLude
Sep 27, 2006 09:19 PM
anomale
Oct 13, 2005 07:00 PM
snatch
Aug 20, 2004 09:56 AM
