HELP d16y7 cranks but doesnt start good spark and fuel?!?!
Old Aug 15, 2006 | 05:50 PM
XLR8 GS-R's Avatar
Default HELP d16y7 cranks but doesnt start good spark and fuel?!?!
THe trusty d16 still will not start. It had a steady coolant leak for a few weeks and then decided to die when merging onto a highway. I replaced plugs, coil, wires, cap and rotor. I am getting perfect spark. I checked the fuel pressure at the filter and it is 40psi (in spec with book). I did a compression test and got
30psi in number 1
35psi in 2
35 in number 3
40 in number 4 (closest to distributor)
I took the head off and found oil in the coolant and coolant in the oil. I saw oil all under the head gasket on the block side... So i assumed it was headgasket. So i replaced the headgasket with all new head bolts. When the head was off i also took off all the valves and re-seated them. I put everything back together and torqued the head bolts in the steps that are shown in the book. When i was tightening there was 2 or 3 bolts that were squeeking when i was torqing them, so i added more oil and still got the sqeeks when i re-tourqued. I then went to start the car and got nothing.
I did another compression test and got:
30psi in #1
35psi in #2
45psi in #3
and 100psi in #4
then i added oil to the cylinders through the spark hole and got 5psi more across the board. WTF IS THE PROBLEM!?!?! I AM PISSED at mi H
Old Aug 15, 2006 | 05:53 PM
Slopoke's Avatar
Do a leak down test and see where the compression is leaking out.
That will help figure out why your #s are so low.
Old Aug 17, 2006 | 01:52 PM
XLR8 GS-R's Avatar
Default Re: (Slopoke)
Hey w/o doing the leakdown test (cause i dont have a tester and they are $$) what do you think it could be? I was thinking warped block
Forgot to mention- its throwing no codes
Modified by XLR8 GS-R at 6:16 PM 8/17/2006
Old Aug 17, 2006 | 04:32 PM
XLR8 GS-R's Avatar
Default Re: (XLR8 GS-R)
bump
Old Aug 19, 2006 | 03:33 PM
XLR8 GS-R's Avatar
bump?
Old Aug 19, 2006 | 03:50 PM
-JSpecEk*9-'s Avatar
wow that sucks sorry i dont kno wha the problem will be but ill give you a bump cuz i want to kno also.......bump
Old Aug 23, 2006 | 03:46 PM
XLR8 GS-R's Avatar
Default Re: (JDMEK-9)
Thanks Ek- anyone have any ideas??? im thinking warped block? BUMPPPPP
Old Aug 23, 2006 | 03:53 PM
mitsuman's Avatar
besides the fact that the comp is super low, is it sparking in the right order?
leak down test will tell you whats going on. seems as though could be going passes the valves. did the timing maybe jumpo a tooth?
but then again all would have low compression. i cant thnk of anything else. crack somewhere?
Old Aug 23, 2006 | 04:12 PM
mitsuman's Avatar
Default Re: (mitsuman)
check your valve clearnce make sure they are within spec
Old Aug 23, 2006 | 04:36 PM
oscarmayer's Avatar
wtf? 4o psi on the cyclinders on a compression test? that's BAD. the motor is blown. it should be like 185 or so.
soccerboo
Sep 30, 2012 07:31 AM
ToKicO
May 9, 2011 03:21 PM
MrPscott
Jul 3, 2007 10:23 AM
frost_0ne
11
Sep 14, 2006 01:57 PM
efb20vtec
May 12, 2006 12:02 PM
