Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
LX with Fogs AND Interior leds ? Limited switch space.
Old Aug 15, 2006 | 05:47 PM
enabi's Avatar
Default LX with Fogs AND Interior leds ? Limited switch space.
I have a friend that recently purchased a 2006 LX Coupe. And not too long ago, she ordered factory fog lights, and the underdash interior illumination leds. I was chosen as the installer. I recieved both boxes yesterday, and upon examination I noticed that both switces go in the same location. Problem is the car came with power mirrors, and that switch doesnt take up one slot, but 2. And thus I dont have space for 1 more switch. What are my options aside from mouting the less important switch somewhere out of sight ?
Old Aug 17, 2006 | 10:03 AM
LeighDango's Avatar
Default Re: LX with Fogs AND Interior leds ? Limited switch space. (enabi)
They say you can't have both installed, it's one or the other.
http://www.hondapartsdeals.com...t.pdf
Old Aug 17, 2006 | 11:37 AM
airportguy770's Avatar
Any way you could splice the two wires together so one switch would run both???
Old Aug 17, 2006 | 07:31 PM
~sp33~'s Avatar
EFB055
lol^^^ i like how they call them courtesy lights, although theyre pretty much neons.
Old Aug 17, 2006 | 09:28 PM
Miracle's Avatar
Default Re: (~sp33~)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ~sp33~ &raquo;</TD></TR><TR><TD CLASS="quote">lol^^^ i like how they call them courtesy lights, although theyre pretty much neons.</TD></TR></TABLE>
Not really. They are LED's which are different. Plus, IMO, they look good by not overpowering, but rather accenting the cars interior. I think it adds a nice little flare.
Ive though about seeing if I couldnt put them in my car.
Old Aug 18, 2006 | 02:50 AM
Demonis's Avatar
I plan to eventually convert that kit to red and put them in my SI... will have to be a hide-away switch though. I don't believe there is any other way.
As per handa-accessories saying you cant install the fogs and courtesy lights together, its because they use the same fuse. Youd have to run one from a direct line. I havent even looked at the fusebox to see if honda has direct line connections there or not. If not you will need a line from the battery...which sucks
Old Aug 18, 2006 | 08:29 PM
enabi's Avatar
Default Re: (Demonis)
I got the fogs and leds installed today, job went pretty smooth and results were great. For now I have the led switch hidden away under the steering column lower panel. I may just cut an openning in the left side coin pocket, it should be totaly hidden, and wont take away from the pocket its self.
Old Aug 19, 2006 | 06:30 AM
06blaksi's Avatar
Default Re: (enabi)
Saw this on 8th civic...he used the 6 led tubes
Old Aug 19, 2006 | 12:39 PM
liketofry's Avatar
Default Re: (06blaksi)
That makes the space-age interior even more spacey. I would go with blue lighting for my LX to match with the blue display
tallguy21
Jul 21, 2013 11:18 AM
blackeg
Mar 5, 2007 09:34 AM
JDMlyfestyle
16
Jan 27, 2005 10:04 PM
BlazinITR
Jan 24, 2003 01:05 PM
