Swapping gearing too difficult/pricey?
Old Aug 15, 2006 | 04:51 PM
uszcrx's Avatar
Default Swapping gearing too difficult/pricey?
Well I am in process of my manual swap and have a CX tranny.. Is it worth it to take apart this thing for an ideal gear ratio or final drive or whatever.. or not??
I am fairly mechanically inclined.. and i dont see a whole lot of info on this..
Also pricing.. EX tranny= much cheaper then doing this? Or could i possibly get a better ratio then that??
Old Aug 15, 2006 | 05:03 PM
schardbody's Avatar
most aftermarket final drives go for $500 and up. you can easily find the info to swap to an EX final drive. its not too difficult, i personally havent done it but watched one of the best do it to mine and it wasnt much work at all. definately cheaper to pick up a used ex tranny and use it if you trust the condition, or use the FD.
Old Aug 15, 2006 | 05:13 PM
uszcrx's Avatar
Default Re: Swapping gearing too difficult/pricey? (uszcrx)
hrmm maybe buying the FD off the ex is an ok idea.. damn stuff so expensive i just wanted to turbo and auto to manual swap!! haha thanks.. Any good places to buy an EX tranny and sell my CX one?
Old Aug 15, 2006 | 05:24 PM
Bense's Avatar
i got a 4.25 final that I can sell you
Old Aug 15, 2006 | 05:27 PM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
i have a 2000 ex tranny that needs a new home....
Old Aug 15, 2006 | 06:06 PM
schardbody's Avatar
buy the FD and swap it, much cheaper.
Old Aug 16, 2006 | 03:25 AM
uszcrx's Avatar
thanks for all the info!
with swapping the final gear.. what will my potential MPH's be and things of the sort?
Old Aug 16, 2006 | 04:32 AM
Eyal 951's Avatar
Don't use that CX tranny unless you are boosted. The gear ratios are terribly long!
Old Aug 16, 2006 | 10:48 AM
uszcrx's Avatar
Default Re: Swapping gearing too difficult/pricey? (Eyal 951)
ok im at work on my phone so bad punctuation.. anyone do the math for the tranny.... i am going to boost but i thought shorter gears are better either way.... anyone calculate how close it would be to an ex tranny? is it an easy transfer?
Old Aug 16, 2006 | 12:20 PM
uszcrx's Avatar
sorry i cant answer pms on my phone.. looking for a tranny with good enough ratios for a greddy kit 7 psi for 14s... maybe 13s with a little help.. what is best? will ex fd and 3rd make it all good or do they require too much modification to fit?
Old Aug 16, 2006 | 12:39 PM
Bense's Avatar
it's a direct swap for your trans
Old Aug 16, 2006 | 01:11 PM
uszcrx's Avatar
Default Re: Swapping gearing too difficult/pricey? (Bense)
ok that sounds good theb..ill be off work in an hour and pm u! hope its not a hard install hah!
Old Aug 16, 2006 | 01:16 PM
Bense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by uszcrx &raquo;</TD></TR><TR><TD CLASS="quote">ok that sounds good theb..ill be off work in an hour and pm u! hope its not a hard install hah!</TD></TR></TABLE>
easy if you're mechanically inclined
Old Aug 22, 2006 | 06:22 PM
uszcrx's Avatar
bump cuz i am buyin final drive and a 3rdd
Old Aug 23, 2006 | 01:14 PM
uszcrx's Avatar
Bump waiting for bense to ship my items!
prelude182
Aug 29, 2009 05:57 PM
SlowHX
Sep 1, 2005 02:44 PM
nikkon
Jun 27, 2005 01:48 PM
turbod16y7vtec
Dec 12, 2002 09:22 AM
