Any Idea what might of cause this??
Old Aug 15, 2006 | 02:05 PM
ITR-2001's Avatar
Default Any Idea what might of cause this??
Anyways the shaving that came of the flywheel is melted right onto the crank
Modified by ITR-2001 at 10:33 PM 5/2/2008
Old Aug 15, 2006 | 02:45 PM
mugenracer's Avatar
Holy crap, it looks like someone beat the hell out of it with a hammer!!
I have absolutely no idea what could cause something like that to happen...but i'm guessing it had to have been done while the wheel was off the engine and not while it was fitted.
Old Aug 15, 2006 | 03:04 PM
ITR-2001's Avatar
Old Aug 15, 2006 | 05:54 PM
ITR-2001's Avatar
I search, but I couldn't find anything similiar to this problem. Any help is appreciated!
Old Aug 15, 2006 | 08:17 PM
ITR#132's Avatar
By chance did you happen to misshift or over rev?
That is the result of loose bolts which could be caused by many things, Im guessing it was an over rev
The Fix- $$$ The flywheel needs to be replaced/repair; for just a little bit more than the cost to repair from a machine shop you could buy a new lighter flywheel. The crankshaft needs to be removed to be repaired/replaced. Cost for repair (including profiling/chamfering/balancing) should be less than a new crankshaft.
Old Aug 15, 2006 | 08:31 PM
ITR-2001's Avatar
Yea I did over rev once on the track..The flywheel is new, but the melted shaving on the crank is gonna be a pain in the *** to fix from what you are saying...Is there any other method which one can do by themself instead of a shop on getting the melted shaving off the crank? Any Ideas or the only way is the shop?
Thx for the reply ITR#132
Old Aug 16, 2006 | 07:45 PM
ITR#132's Avatar
Default Re: (ITR-2001)
You should talk to a machine shop if they could somehow resurface the crank with it still in the car. All you really need is a touch to get rid of the high spot to get the surface flat so that the new flywheel can mate up (hopefully that wont upset the balance of the crank)
Old Aug 17, 2006 | 06:29 AM
ITR-2001's Avatar
Default Re: (ITR#132)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR#132 &raquo;</TD></TR><TR><TD CLASS="quote">You should talk to a machine shop if they could somehow resurface the crank with it still in the car. All you really need is a touch to get rid of the high spot to get the surface flat so that the new flywheel can mate up (hopefully that wont upset the balance of the crank)</TD></TR></TABLE>
Took of the tranny/clutch/flywheel and did that yesterday...I had a friend just grind the lump away and smooth out the surface...After that it seem back to normal, but I'm not sure if it will upset the balance of the crank though...
Thx everyone for your suggestion!
Old Aug 17, 2006 | 08:35 AM
Rene M's Avatar
Moisture between the flywheel and crank.. Those are rust erosion marks/pits ..
Old Aug 17, 2006 | 12:12 PM
citrus3000psi's Avatar
Default Re: (Rene M)
Oxidation
Old Aug 17, 2006 | 08:25 PM
ITR#132's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rene M &raquo;</TD></TR><TR><TD CLASS="quote">Moisture between the flywheel and crank.. Those are rust erosion marks/pits .. </TD></TR></TABLE>
Those pits on the flywheel was welded onto his crank shaft. Metal was transfered not eroded.
If there was moisture or even soaking wet between the flywheel and crank, it would of dried once driven.
Old Aug 18, 2006 | 12:57 AM
mRek9R's Avatar
Let me know how it goes Shoua, 8)
qpe
May 12, 2009 04:13 AM
Boosted_01 R
Dec 8, 2008 12:53 PM
ITR-2001
Aug 16, 2006 02:02 PM
Bantam
Dec 30, 2003 10:09 AM
