Fogging Issues in Honda's Interior
Old Aug 15, 2006 | 01:59 PM
Boosted193's Avatar
Default Fogging Issues in Honda's Interior
Noob to the Honda forum. Formally a Mazda forum member & now back in the hunt for an Si or Hatch. I owned Accord, and 2 Civics, then my Mazda, both of my Civic i owned were 95 and older, and every one of them had some serious interior window fogging problems. Im just curios if A) anyone found a way to resolve this issue or B) what year's did Honda themselves resolve the issue where the interior did not fog? Sorry if this is a re-post, tried searching everything and nothing came back! Thanks again peoples!!
193
Old Aug 15, 2006 | 02:11 PM
racer22's Avatar
Default Re: Fogging Issues in Honda's Interior (Boosted193)
Well, I had a problem with my windows fogging up when it cold outside. So i went to vatozone and bought some stuff, it is in a yellow bottle, that you rub on the glass so that the windows dont fog up. It is a small little yellow bottle. I just wiped the stuff on the windows, and the fogging on the windows went away.
Old Aug 15, 2006 | 02:15 PM
SiYouLater's Avatar
Default Re: Fogging Issues in Honda's Interior (racer22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racer22 &raquo;</TD></TR><TR><TD CLASS="quote">Well, I had a problem with my windows fogging up when it cold outside. So i went to vatozone and bought some stuff, it is in a yellow bottle, that you rub on the glass so that the windows dont fog up. It is a small little yellow bottle. I just wiped the stuff on the windows, and the fogging on the windows went away.</TD></TR></TABLE>
Rain X?
Old Aug 15, 2006 | 02:28 PM
BiffStroganoffsky's Avatar
Rain-X should be a black bottle but that may be for their exterior product. However, they also have a wipe that is saturated with the solution for one time use versus the bottle, but I seem to remember that in black also.
Old Aug 15, 2006 | 02:41 PM
92ehatch's Avatar
Default Re: (BiffStroganoffsky)
rainx anti fog works for a while, but ifound out after its been used about 3 times on the window, when the sun hits it, there is an annoying streaky glare that just will not ever ever come off.
Old Aug 15, 2006 | 02:46 PM
JDMlyfestyle's Avatar
Default Re: (93cb7sedan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93cb7sedan &raquo;</TD></TR><TR><TD CLASS="quote">rainx anti fog works for a while, but ifound out after its been used about 3 times on the window, when the sun hits it, there is an annoying streaky glare that just will not ever ever come off.</TD></TR></TABLE>
get a empty gallon milk jug.. Pour a bottle of Rubbing alcohol in it. then pour in 1/2 bottle of Vinegar then fill the rest with water.. Streek free and will take anything off of the windows.
Old Aug 15, 2006 | 03:43 PM
Boosted193's Avatar
yeah....I tried rain-x worked pretty good before, worked pretty good for while. Just after while got an annoying smug and glare to it. What year did they finally elimnate this problem? I'm on the hunt for a Civic ONCE AGAIN, but dont wanna deal with the BS fogging, unless i have too....
Old Aug 15, 2006 | 04:44 PM
Echo7847's Avatar
Default Re: (Boosted193)
hot water and vinegar works well.
Old Aug 15, 2006 | 06:01 PM
siege911's Avatar
do you mean fogging like when it's cold outside, and you breath on the window? or like your defroster doesn't defog them?
Old Aug 15, 2006 | 06:32 PM
fmrprojects's Avatar
Default Re: (siege911)
i have no problems with mine. just keep ur windows clean on the inside and you wont have any problems.
Old Aug 15, 2006 | 06:50 PM
Jhonny Ricer's Avatar
Default Re: (fmrprojects)
Rain X Anti Fog Ruins windows used it on my sisters car for 3 years, And it deteriorated the laminate protector on the inside of the window.. So it would constantly have haze on it. My advice, use rubbing alcohol on your window instead. It will keep then from fogging up and works as long as Rain X would work.
Old Aug 15, 2006 | 07:13 PM
Frozen E's Avatar
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted193 &raquo;</TD></TR><TR><TD CLASS="quote">What year did they finally elimnate this problem?</TD></TR></TABLE>
Uhmmm, honda isn't god. It's called nature. Windows WILL fog in certain conditions. Unless you have AC in your car you really can't do **** about it other than turn your blower on high and wait for the stuff to dry up or keep paper towels in your car and get busy wiping.
Old Aug 15, 2006 | 07:51 PM
HondaEK9's Avatar
i heard if you put it on outside air than recirculate that helps. or whatever the button is called with the arrow from outside the car going in. sry for any confusion just tryin to help
Old Aug 18, 2006 | 06:53 PM
Default Re: Fogging Issues in Honda's Interior (HondaEK9)
Try breathing on your window during winter does it fog THIS CANT BE ELIMINATED ASSHAT ITS CALLED CONDENSATION! Turn on your ac or fresh air control, And be patient or how about I fix the whole problem for you all together and take out your damn windshield!!!
Old Aug 18, 2006 | 07:18 PM
tempsohc's Avatar
microfiber.....helps allot too
Hammer_head
Mar 23, 2010 08:33 PM
billboard
May 22, 2008 09:47 AM
kiddcarbuff
Mar 22, 2006 04:48 PM
JTTeG_X
Dec 4, 2005 06:05 PM
MassScene
Mar 22, 2005 02:30 AM
