ARP Torque Pattern
Old Aug 15, 2006 | 01:09 PM
Toroke's Avatar
Default ARP Torque Pattern
How do I torque down my ARP's on my Z6? Is there a certain pattern? If so please provide a diagram. I'm outside now trying to do this... I'm gonna torque to 67 ft-lbs with moly lube. Thanks!
Modified by Toroke at 2:31 PM 8/15/2006
Old Aug 15, 2006 | 01:32 PM
Toroke's Avatar
Default Re: ARP Torque Pattern (Toroke)
Bump, need an answer, can't go on without.
Old Aug 15, 2006 | 01:41 PM
NonovUrbizniz's Avatar
Loved
It's the same pattern as stock...
You start in the middle and work your way out in a criss-cross pattern...
09/5/1/3/7
10/6/2/4/8
Frankly I'm not sure that's the EXACT pattern... but it also isn't THAT important...
You just want to start in the middle and work your way out in a criss-crossing pattern...
ALSO BE SURE that you do this in steps.. in other words DO NOT torque them to 60 on the first run...
I do it so they're all handtight then back over it 1/2 - 1/3 of a turn and keep doing that only turning each bolt/nut 1/2-1/3 of a turn each time till I hit the desired torque.
It'll prob take 3-4 passes.
Old Aug 15, 2006 | 01:45 PM
Toroke's Avatar
Default Re: ARP Torque Pattern (NonovUrbizniz)
Thanks so much. Now, at this point, I just called ARP and they recommended I take them to 60 ft-lbs... The first guy said it's fine to take them an extra 5, but I had him get a second opinion and the guy he asked apparently has been around for some time there, and said to just go with 60. Sound good?
Old Aug 15, 2006 | 01:55 PM
Loved
I wouldn't exceed 60lbs unless you're planning on HEAVILY boosting the car...
That's really the only concern is sealing the HG.. .SOME TIMES rediculous amounts of boost will cause a leak... but not very often and I've never heard of it on a civic...
Also keep in mind it's an aluminum block... if you over torque the studs and F up the threads in the block it'll be a NIGHTMARE.
Stick with whatever the ARP guy says.
Old Aug 15, 2006 | 03:09 PM
nonsense's Avatar
in the helms for a d16y7 (and 8) says
9 3 1 5 7
8 6 2 4 10
Make 4 passes:
1 - 10 to 14 lb-ft
1 - 10 to 36 lb-ft
1 - 10 to 49 lb-ft
1 and 2 to 49 lb-ft again.
for a B16A it says:
9 5 1 3 7
8 4 2 6 10
and 2-3 steps to 61 lb-ft.
Basically the same thing, but opposite X pattern, so I doubt it makes a difference.
ray.riddler92
Jul 27, 2011 05:07 PM
onwisconsin81
Apr 5, 2010 01:25 AM
NuRon
Mar 31, 2007 09:41 PM
Smith Wise
Apr 15, 2003 04:02 PM
jonsteR
Aug 10, 2001 08:55 AM
