Wiring the knock sensor...
Old Aug 15, 2006 | 12:37 PM
mattmw88's Avatar
Default Wiring the knock sensor...
When I swapped the motor (had an f22a1) I originally had a knock sensor code. I rewired a bunch of stuff and the code went away (although I don't think I touched the kncok sensor)... temperarily.
I went to take a look at rewiring the sensor and found out that it is a sheilded wire. We used the f22 harness which has no knock sensor.
According to the wiring diagram the knock sensor ground should tap into:
-the negative on the shielded O2 ground(which is also grounded to the block and also taps onto B2 of the ecu.
- the shielded part of the CYP, TDC, and CKP sensors.
-also to A26 that goes to ECU.
My question is this: how do I wire it all? should I take a shielded wire, ground it at the ecu, block, and by the knock sensor as well as tapping into all the other sensors?
Do I even need to use a shielded wire? can I get a way with a regular wire from the ecu to the sensor?
Is there an easy way to get rid of the sensor, or to stop the code from tripping aside from getting a P28 and have it remapped?
Please, anyone with some insight I would greatly appreciate your help as I am about to take a trip that is 12 hours each way.
mustninty20
Dec 19, 2008 03:36 PM
quicky_hatch12
Oct 7, 2005 11:59 AM
tc_gts
11
May 4, 2005 05:26 AM
ddong2lee
Mar 4, 2004 05:06 AM
EF_LSVtec
Apr 10, 2003 11:25 AM
