B18a1 into a Civic EF
Old Aug 15, 2006 | 11:43 AM
B20EG's Avatar
Default B18a1 into a Civic EF
Im trying to put a b18a1 into my friends civic EF Hatch.I have the motor in already but im confused with the wiring part.Wat do i have to do?
Old Aug 15, 2006 | 11:45 AM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: B18a1 into a Civic EF (B20EG)
search, or be alot more specfic, like what part is giving you a hard time are you doing mpfi? is the car being turned to obd1?
Old Aug 15, 2006 | 08:12 PM
B20EG's Avatar
Default Re: B18a1 into a Civic EF (***-assin)
yea we took the motor from a 1990 Integra LS and it's mpfi also i think but the Civic Ef my friend told me it was a 1.5 and only ran on 2 injectors.but the computer from the integra pluged right up.so im guessing there both obd-o.but the wiring is all diffrent.I have no idea how to work that.
Old Aug 15, 2006 | 08:47 PM
IndySporty's Avatar
go on ebay and buy one of the "swap CD's" and it has tons of write ups on how to change over the wiring they're only like 5 bucks shipped.
Old Aug 15, 2006 | 11:23 PM
DPSJosh's Avatar
Default Re: (IndySporty)
Search for DPFI to MPFI wiring.
Old Aug 16, 2006 | 01:09 AM
jack_attack's Avatar
why spend 5 bucks on a cd that you have to wait for when you have all the information you'll ever need right on this site NOW and FREE
Old Aug 16, 2006 | 07:32 AM
crxnj's Avatar
Default Re: (jack_attack)
http://fourthgenhatch.net
go to how-to and read up on the mpfi conversion.......
Old Aug 16, 2006 | 07:57 AM
ludesrv's Avatar
Wiring is plug and play, but you must wire MPFI, once that's done, it's good to go aslong as ECU and engine is OBD0.
Old Aug 16, 2006 | 08:30 AM
RBR93teg's Avatar
send the 1.5 engine harness and the b18 engine harness to rywire.my friend did a swap like that himeself and he has had nothin dut problems.i did the swap and sent my stuff to rywire and i havent had anyproblems at all.good luck
Old Aug 16, 2006 | 09:14 AM
B20EG's Avatar
Default Re: B18a1 into a Civic EF (rbr88gt)
yea wouldent be easier just to wire it up that to spend almost 150 buck on a jumpuer
Old Aug 16, 2006 | 09:16 AM
ludesrv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20EG &raquo;</TD></TR><TR><TD CLASS="quote">yea wouldent be easier just to wire it up that to spend almost 150 buck on a jumpuer
It's 4 wires, a resistor box and a different plug for the dizzy. I can do it no problem. I did an MPFI by myself on my civic and the mpfi swap has never given me troubles, it's everything else that has!
Old Aug 16, 2006 | 06:48 PM
B20EG's Avatar
Default Re: B18a1 into a Civic EF (ludesrv)
also my we just pluged up the motor but we havent run the wire for the injectors or the distribitor and when we turn the key to turn the light on the engine tried to turn on with giving the signal with the key.could it be cuz i havent ran the wires?
Old Aug 16, 2006 | 08:05 PM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20EG &raquo;</TD></TR><TR><TD CLASS="quote">also my we just pluged up the motor but we havent run the wire for the injectors or the distribitor and when we turn the key to turn the light on the engine tried to turn on with giving the signal with the key.could it be cuz i havent ran the wires?</TD></TR></TABLE>
you gotta convert to mpfi.....do it already...look here everthing is there including pictures http://fourthgenhatch.net/mpfi.html
it wont start how you have it....
Old Aug 16, 2006 | 08:20 PM
doublethink's Avatar
Default Re: (DPSJosh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DPSJosh &raquo;</TD></TR><TR><TD CLASS="quote">Search for DPFI to MPFI wiring.</TD></TR></TABLE>
or use fouthgenhatches guide.
you MUST DO THIS. then the engine will work.
thats all there is to it. if you dont want to, send the wires out to someone to do it for you.
shervang9
28
Mar 16, 2011 12:00 AM
B-serious
Nov 9, 2006 09:18 PM
integra95gsr
Dec 1, 2005 08:51 PM
drowzysleeper
Aug 25, 2005 02:49 PM
