another clutch won't engage problem!
I searched before posting!!
i was driving slowly, pressed my clutch pedal and it stayed to the floor. i backed it up with my foot and then it returned to normal (pedal goes back up as usual when I press on it)
but when I tried to put it in gear and release the clutch pedal, nothing happens
I can put it ANY gear, with engine on or off, but when I release the clutch its as if I was in neutral, car wont budge. no weird noise from tranny or clutch
fluid level is fine, clutch pedal feels normal (exept for when it stayed to the floor..), axles are in tight, ... anything else i should check before removing the tranny? can a blown up clutch do this?
car is 94 Integra. exedy stg1 clutch (approx 5000kmson it). engine is b20 vtec if it matters....
TheSwift1
Jun 10, 2002 06:01 AM
