how do i get this out?
Old Aug 15, 2006 | 11:04 AM
92integra-R's Avatar
Default how do i get this out?
i tring to get the lower ball joints out on my 92 DA. when i get it coming out the ball joint hits this ring
how does this come out?
Old Aug 15, 2006 | 11:07 AM
90dateg's Avatar
go to autozone and rent a ball joint puller -
Old Aug 15, 2006 | 11:09 AM
Default Re: (90dateg)
why do i need that? the ball joint is loose but hitting that ring. no problems moving the ball joint till that point.
Old Aug 15, 2006 | 11:12 AM
90dateg's Avatar
Default Re: (92integra-R)
that is what ive always done it only takes a few minutes with the puller . and when you take it back you get your money back - so basically its free to rent and makes things alot easier .
Old Aug 15, 2006 | 11:27 AM
RJonathan's Avatar
Default Re: how do i get this out? (92integra-R)
looking at the pictures your ball joint is already out. when I did my ball joint on my prelude and integra, I used a flat head screw driver and slowly try to pry it out or use a rubber malet and just give it a couple of taps and that ring should just fall out. just be clever it'll come out its not stuck in there trust me.
Old Aug 15, 2006 | 11:35 AM
Default Re: how do i get this out? (RJonathan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RJonathan &raquo;</TD></TR><TR><TD CLASS="quote">looking at the pictures your ball joint is already out. when I did my ball joint on my prelude and integra, I used a flat head screw driver and slowly try to pry it out or use a rubber malet and just give it a couple of taps and that ring should just fall out. just be clever it'll come out its not stuck in there trust me. </TD></TR></TABLE>
thanks man did you reuse those rings?
Old Aug 15, 2006 | 01:34 PM
importdude2000's Avatar
u need to PRY THE AXLE PLATESEAL with a FLATHEAD
then it comes out(balljoint
didnt notice someone said it already ops
and reuse it after just mallet it back in
Old Aug 15, 2006 | 03:46 PM
SOLID00's Avatar
Default Re: (importdude2000)
Just do NOT bend it. I had one crack after bending it back . Make awful noise
Old Aug 15, 2006 | 04:46 PM
GreddyTegra's Avatar
dude you could always use a benchpress
Old Aug 15, 2006 | 04:49 PM
Dforce's Avatar
That's what she said!
Default Re: how do i get this out? (GreddyTegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GreddyTegra &raquo;</TD></TR><TR><TD CLASS="quote">dude you could always use a benchpress</TD></TR></TABLE>
WhiteOnRice
Aug 18, 2024 11:11 AM
PatrickGSR94
Suspension & Brakes
18
May 12, 2010 09:55 AM
89efhatchcrap
Suspension & Brakes
24
Feb 17, 2009 10:36 AM
LaterApex
Suspension & Brakes
Oct 21, 2005 09:33 PM
ultraforce77
Jul 15, 2004 02:59 PM
