swap ?
Old Aug 15, 2006 | 10:36 AM
dkrex001's Avatar
Default swap need help
i have a obd1 b18a1 in a 90 crx dx the wiring is just fine and was done by rywire they did a great job.
but i am getting cel codes:
3 map sensor
7 tps
12 egr
15 ignition output signal
17 vss
41 primary oxygen sensor heater
i have a brand new oxygen sensor and vss and tps and iacv.
the car runs good but at idle it goes up and down from 1000 rpms to 2000 rpms just like it is the iacv.
the motor came out of a 92 integra that was switched from auto to manual. the integra did not do it before the switch from auto to manual.
if any one has any help for me it would really help thanks
Old Aug 15, 2006 | 11:55 AM
BlackLudeSi's Avatar
Default Re: swap need help (dkrex001)
It sounds like you might have a bad ground or one not connected with all those codes, did you try resetting it to see if they come back? As far as your jumping idle it could also be you FITV hears a good write up on how to clean it, hope it helps https://honda-tech.com/zerothread?id=1564019
snowboarderbrt
17
Sep 4, 2014 01:42 PM
chris.deyoung
Jun 17, 2008 01:37 PM
chris.deyoung
29
Jun 12, 2008 11:05 AM
weaslehunter1
Jul 1, 2005 10:27 PM
