ID a motor????
friend of mine is getting me a GSR US SPEC motor (B18C1) for 1 G yes that is right and he is throwing the MOTOR, Tranny, ECU, all sensors WIRE HARDNESS and well what is the code other than to tell if the motor is in good condition what about the COMPUTER what is the CODE to look for on the computer i believe is a 97 GSR motor i know is OBD1 (COMPUTER TYPE ) but other than that i cant tell apart I know THEY POSTED a link please HELP QUICK ill be looking at the motor ON MONDAY
THANK YOU
FELIX
THANK YOU
FELIX
Look on the actual computer. There is a sticker on one of the sides with a Honda part #. It will be split into 3 sets of numbers (ie. XXXX-XXX-XXXX). The middle set of numbers should be "P72" to designate it is from an Integra GSR. If the motor is from a '97 GSR, it will be OBDII, not OBDI. The only OBDI 1.8L GSR's were made in 1994 and 1995. The 1996 started with OBDII. I'm not sure if you can tell if the computer is OBDI or II from looking at the actual computer. Someone please post to clarify!!!
B96v6
B96v6
1G eh....so where was it STOLEN from. Thats pretty cheap for GSR MOTOR. make sure you check to see if the VIN is CLEAN. If it is CONGRADULATIONS on such a good deal. and quit WHINING about the ECU.
coquieg6
Aug 6, 2009 06:59 AM
