How to keep flywheel from rotating while torquing down flywheel bolts.
Old Aug 15, 2006 | 05:44 AM
PrinceAli132's Avatar
Default How to keep flywheel from rotating while torquing down flywheel bolts.
I remember reading it somehwere but can't find the thread for the life of me. So if someone could tell me what to do, i would really appreciate it. Thanks in advance.
Ali
Old Aug 15, 2006 | 05:45 AM
Dave_B's Avatar
Is this ITR related...
Old Aug 15, 2006 | 05:47 AM
Default Re: (Dave_B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave_B &raquo;</TD></TR><TR><TD CLASS="quote">Is this ITR related... </TD></TR></TABLE>
Bastard!!! It has a B18 something.
And it does have a ITR AEM CAI and the optional kit, does that help.
Ali
Old Aug 15, 2006 | 05:51 AM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: (PrinceAli132)
Have someone hold it.....
Old Aug 15, 2006 | 06:10 AM
whitelightning's Avatar
Default Re: (walker111)
I bought the 'special tool' from honda. works great
Old Aug 15, 2006 | 07:05 AM
Eva01's Avatar
Default Re: (whitelightning)
Stick a screwdriver in one of the holes of the flywheel and brace it against the oil pan with a block of wood in between.
Old Aug 15, 2006 | 08:51 AM
JOHN WAYNE's Avatar
Default Re: (Eva01)
get a chain and bolt one end of the chain to the flywheel through one of the pressure plate mounting holes...then bolt the other end to the block somewhere...
Old Aug 15, 2006 | 09:03 AM
businessman_b's Avatar
^^Woops....you beat me to it.
I like to use a hanger. Use on of the pressure plate bolts and one of the tranny-to-block bolts; wrap the hanger around them. Works every time...
Old Aug 15, 2006 | 09:04 AM
Default Re: (JOHN WAYNE)
I used that screwdriver trick and it worked like a charm. Thanks everyone.
Ali
Old Aug 15, 2006 | 09:11 AM
Dave_B's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrinceAli132 &raquo;</TD></TR><TR><TD CLASS="quote">I used that screwdriver trick and it worked like a charm. Thanks everyone.
Ali</TD></TR></TABLE>
Your still slow at street racing... /neo
Old Aug 15, 2006 | 09:12 AM
hialeahzbg's Avatar
i used the same punch to take out the bitch pin and stuck it threw the screw hole and spinned it till it hit something and wouldnt spin anymore....worked perfect...
Old Aug 15, 2006 | 10:56 AM
hayabusa160's Avatar
Default Re: (hialeahzbg)
usuaully if the motor is still in the car i'll put a pipe on one of the teeth and prop the pipe on the floor so it will keep the flywheel from turning like this O\
Old Aug 15, 2006 | 03:59 PM
the_grinder's Avatar
Default Re: How to keep flywheel from rotating while torquing down flywheel bolts. (PrinceAli132)
Unless I completley misunderstood the question - this is what I do.
Use a long breaker/ johnson bar with a 19mm socket and put it on the crank pulley. Tighten down the flywheel and the bar will eventually work around and catch on something such as the ground. This way is much more stable and safe than the other methods listed.
Old Aug 15, 2006 | 04:27 PM
Your still slow at street racing... /neo</TD></TR></TABLE>
Bwahahahahahah
Thanks again guys
Ali
Old Aug 15, 2006 | 06:03 PM
chad's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrinceAli132 &raquo;</TD></TR><TR><TD CLASS="quote">I remember reading it somehwere but can't find the thread for the life of me. So if someone could tell me what to do, i would really appreciate it. Thanks in advance.
if you can't figure out how to do that you shouldn't be working on a car!!!
Old Aug 15, 2006 | 07:03 PM
Honda Sport's Avatar
Default Re: How to keep flywheel from rotating while torquing down flywheel bolts. (the_grinder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the_grinder &raquo;</TD></TR><TR><TD CLASS="quote">Unless I completley misunderstood the question - this is what I do.
Use a long breaker/ johnson bar with a 19mm socket and put it on the crank pulley. Tighten down the flywheel and the bar will eventually work around and catch on something such as the ground. This way is much more stable and safe than the other methods listed. </TD></TR></TABLE>
that's how I did it with the motor out of the car. actually, that's how I did it with the motor in the car also.
Old Aug 15, 2006 | 07:39 PM
Black R's Avatar
25 Year Member
screwdriver or crank pulley tool
Old Aug 15, 2006 | 08:15 PM
Default Re: How to keep flywheel from rotating while torquing down flywheel bolts. (chad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad &raquo;</TD></TR><TR><TD CLASS="quote">
if you can't figure out how to do that you shouldn't be working on a car!!!</TD></TR></TABLE>
Then i would never learn how to do anything on the car myself, and would end up paying *** raping prices just to get anything done. And we all start somewhere.
And i did have an idea on how to stop it from turning but wanted to verify my method as to make sure i wouldn't mess anything up.
Ali
Old Aug 15, 2006 | 08:23 PM
DOMKID's Avatar
screwdriver on the flywheel teeth . Or put a socket and long ratchet on the crank pulley,it will lock up against the floor and prevent the flywheel from moving.
Old Aug 16, 2006 | 10:21 AM
chad's Avatar
Moderator
Default Re: How to keep flywheel from rotating while torquing down flywheel bolts. (Felix.)
this screw driver method......yeah will break the aluminum....do it right and get the right tool
Old Aug 16, 2006 | 10:33 AM
B18CXr's Avatar
Screwdriver into the block web casting.
Old Aug 16, 2006 | 10:35 AM
Eddiebx's Avatar
i jsut thread in a tranny case bolt, then u can stick a pry bar or large screw driver against it and the flywheel teeth.
this method should break nothing as it is close to how the manual reccomends you lock it inplcae. jsut that they have a fancy dooo hickey that bolts to the block with a tooth sticking out to lock the ring gear,
Old Aug 16, 2006 | 01:10 PM
92TypeR's Avatar
FSAE
Default Re: (Eddiebx)
Or just use the screwdriver method
Old Aug 16, 2006 | 11:13 PM
phyzJunkieCivic's Avatar
From: Dont You Just Love Lynn Cops, Boston MA, USMA
vise grip the flywheel an rotate it till it jams to the bottom of the block
92 gs INTEG
Jan 31, 2007 09:42 PM
jdmekcivic2eg
Mid-Atlantic (Sales)
May 26, 2006 12:40 PM
IntegraGSR23
Oct 3, 2005 04:19 PM
STS_Underdog
Aug 2, 2004 02:03 PM
3rdGteg
Sep 3, 2002 09:52 PM
