Stronger timing belt required for 400hp drag H22 CRX?
I am currently building up my h22 engine and am looking at the possibility of a power enterprises or simular aftermarket timing belt? From people that have been in the game a while would u say they are worthwhile?
I am currently using a stock honda belt. As in the title my goal is just a little under 400hp
Thanks
Thanks
I wouldn't ever worry about the stock belt if you get the tension correct. People don't break belts because the belts are weak, they break them because they don't know WTF they are doing.
If your really looking for a stronger one then a Greddy belt would do but like stated before the stock one is perfectly fine with that hp. Just know what your doing when putting it on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 86si »</TD></TR><TR><TD CLASS="quote">OEM honda works fine</TD></TR></TABLE>
if your looking for something stronger then greddy is good and also Toda makes a nice belt...i currentlyrun Toda and havent had problems but OEM should be fine with that power....i like to run my belts a little tight so i dont want the oem one to stretch so i went with a Toda
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedh22a »</TD></TR><TR><TD CLASS="quote">Does TODA make an H22 belt??</TD></TR></TABLE>
im not sure actually
Other people, as well as us do 700whp+ on OE timing belts all the time, so I think you'll be fine... That is unless you want something "pretty" (which in reality actually looks gay)!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4piston »</TD></TR><TR><TD CLASS="quote">I wouldn't ever worry about the stock belt if you get the tension correct. People don't break belts because the belts are weak, they break them because they don't know WTF they are doing.</TD></TR></TABLE>
I've ran OEM timing belts on all of my turbo set-ups. I was running an OEM h23 belt on my old set-up that put out a little over 500whp.
I plan on running an OEM belt on my new set-up which should hit around the 700 marker.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XPRORWDTECH »</TD></TR><TR><TD CLASS="quote">what does hp have to do with it?</TD></TR></TABLE>
Valve-train does. I guess in the turbo world people like to address this by power.
If your using a serious valve spring with a lot of seat pressre along with a high lift cam I would probably recommend an aftermarket one. On a side note, Gates is getting into the aftermarket game. I don't know how the prices look, but here's a link to their page.
http://www.gates.com/brochure....=5061
ETDRacing.com recently designed some timing belt tensioners for Vibrant Performance. They were built due to some experiences with high spring pressure and high compression engines skipping a tooth when the motor was shut down.
I know ETDRacing.com has the B and H in stock currently.
This is the B series version, but i know he has an H version also. Sould help you if your worried.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93LSivic »</TD></TR><TR><TD CLASS="quote">If your using a serious valve spring with a lot of seat pressre along with a high lift cam I would probably recommend an aftermarket one. On a side note, Gates is getting into the aftermarket game. I don't know how the prices look, but here's a link to their page.
http://www.gates.com/brochure....=5061</TD></TR></TABLE>
part number:T247RB for GSR
part number:T184RB for LS
apparently, the H22 gets the shaft yet again
these are supposedly 300 times stronger than stock
http://www.gatesracing.com/timing.cfm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XPRORWDTECH »</TD></TR><TR><TD CLASS="quote">not the correct way then is it?
so he should be asking about spring pressures instead.</TD></TR></TABLE>
yea the old school skunk2 valve springs would cause my timing belts to snap.
since then i've been anti-skunk2. oh well they are into the all motor scene anyways.
