clutch fluid the same as power steering or brake fluid?
I use dot 4 in my non-ABS brakes. There is no harm in it. Dot 4 boils at a higher temp. and you could use dot 4 in your clutch too, it wouldnt make a difference, I use it just because I dont see the need to buy two diff bottles of fluid.
but this thread is not about the difference between dot 3 or dot 4, etc.
edit: now that I think about it, I think I use dot 5. Why, you ask? because I can, and because I race my car sometimes, so
lol
lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sol2hatch »</TD></TR><TR><TD CLASS="quote">edit: now that I think about it, I think I use dot 5. Why, you ask? because I can, and because I race my car sometimes, so
lol</TD></TR></TABLE>
I hope you're not using DOT 5, considering that it is silicone-based and will coagulate when mixed into the system with any residual glycol-based DOT 3/4/5.1 fluids.
lol</TD></TR></TABLE>I hope you're not using DOT 5, considering that it is silicone-based and will coagulate when mixed into the system with any residual glycol-based DOT 3/4/5.1 fluids.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">
I hope you're not using DOT 5, considering that it is silicone-based and will coagulate when mixed into the system with any residual glycol-based DOT 3/4/5.1 fluids.</TD></TR></TABLE>
i flushed the system when i put the fluid in. I am still not really sure which one I am using though, lol. maybe it is just dot 4. whatever.
explictness
Feb 21, 2007 08:37 PM
I would give you a cookie if I had one. LOL.
