Fan switch or relay or fan motor?
Old Aug 14, 2006 | 08:00 PM
tigueremalo's Avatar
Default Fan switch or relay or fan motor?
Ok so one of my frined have a 91 integra LS and the fan motor only turns on when he puts it on 4 which is the one that sends alot of air but my question is Why doesnt the fan turn on in either 1 2 3 is it a relay or is the switch broken or is the motor gone?
Old Aug 15, 2006 | 06:18 AM
VDo's Avatar
VDo
Default Re: Fan switch or relay or fan motor? (tigueremalo)
It's the blower resistor. Around $30 at the dealer.
Old Aug 15, 2006 | 06:30 AM
93_teg_CT's Avatar
Default Re: Fan switch or relay or fan motor? (VDo)
Ok well I don't mean to steal the thread but I have a simaliar problem.
My blower was working 1-2-3 but 4 didn't work, then one day none of them work. Same thing? Is there more than one resistor?
Old Aug 15, 2006 | 07:42 AM
Duane_in_Japan's Avatar
Default Re: Fan switch or relay or fan motor? (93_teg_CT)
I would hot wire the motor and see if it works now (it will be on high), speed no. 4 may be a transistor instead of the resistor.
Old Aug 15, 2006 | 08:18 AM
VDo's Avatar
VDo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93_teg_CT &raquo;</TD></TR><TR><TD CLASS="quote">Ok well I don't mean to steal the thread but I have a simaliar problem.
My blower was working 1-2-3 but 4 didn't work, then one day none of them work. Same thing? Is there more than one resistor?</TD></TR></TABLE>There's one resistor module with three resistors on it. The resistors are for blower settings 1,2,3. The 4th (full power) setting bypasses the resistors completely.
Old Aug 15, 2006 | 02:20 PM
do you know where is that resistor located in the blower??
Old Aug 15, 2006 | 08:09 PM
VDo's Avatar
VDo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tigueremalo &raquo;</TD></TR><TR><TD CLASS="quote">do you know where is that resistor located in the blower??</TD></TR></TABLE>It's right on the blower behind the passenger knee panel. It's held in with two screws and has a 4-pin harness attached to it.
#7 in this pic:
apexi_rsx
Jul 19, 2013 07:43 PM
Nick998
Dec 22, 2011 06:47 PM
dyce_b17
Aug 9, 2011 04:39 PM
schueytenten
15
Aug 8, 2008 12:28 AM
mrlover
Dec 31, 2007 07:33 PM
