Timing belt Help
Old Aug 14, 2006 | 05:24 PM
B!^A@'s Avatar
Default Timing belt Help
i have a B16a2 and im just curious on this here it goes! my timing belt is looser on the side facing towards you when you open the hood and the other side closest too the fiirewall is tight as hell!
Old Aug 14, 2006 | 06:32 PM
wakeboard_dude5's Avatar
Default Re: Timing belt Help (B!^A@)
whoever did the timming belt didn't do it right. I think the helms tells exactly how to tighten it correctly. pretty much when its on you loosen the tensioner bolt, turn the crankshaft so the oil pump gear goes counter-clockwise 3 teeth, then tighten the tensioner bolt to 33ft.lbs? I may have missed a step but that's the proper way to do it. I would say redue it just to make sure you don't hurt your valvetrain
Old Aug 14, 2006 | 09:24 PM
hondamark35's Avatar
nobody did the belt wrong just because of that... that just means the slack is ending up at the front when you cut the motor off...normal
marymiller29456
Classic Hondas
Oct 31, 2012 12:03 PM
slide inside
Oct 22, 2009 09:25 AM
BACKintheDA
Sep 19, 2004 03:26 PM
Luserkid
Apr 10, 2003 06:41 PM
smkngsr
Apr 16, 2002 03:01 AM
