need help finding a clutch
Old Aug 14, 2006 | 05:08 PM
kantfadedisazn's Avatar
Default need help finding a clutch
ok i have a crx with a jdmb16 the tranny is S1 tranny witch is cable, but i cant seem to find a clucth on any site, everything is for hydro, how can i find a dam clucth and are all the bseries clutches interchangable?
Old Aug 14, 2006 | 05:42 PM
.Manny.'s Avatar
Touching My Member
Default Re: need help finding a clutch (kantfadedisazn)
look for a 90-91 integra clutch
Old Aug 14, 2006 | 06:38 PM
Default Re: need help finding a clutch (90_EF_Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90_EF_Si &raquo;</TD></TR><TR><TD CLASS="quote">look for a 90-91 integra clutch </TD></TR></TABLE>
why that year wouldnt 92 or 93 work too im asking cuz im cluless
Old Aug 14, 2006 | 06:54 PM
boostedblkef's Avatar
i got a s1 trans with a 92 clutch
Old Aug 14, 2006 | 06:57 PM
La EF-8's Avatar
im all for exedy stage 2 when you pay for a factory spec one. thanks options auto
Old Aug 14, 2006 | 07:46 PM
B16-CRX's Avatar
I got an exedy organic off ebay for a 91 integra. Just search b16 clutch on ebAy
Old Aug 14, 2006 | 08:12 PM
dkrex001's Avatar
i have a s1 transmission with a 98 crv clutch
Old Aug 14, 2006 | 08:39 PM
crxnj's Avatar
Default Re: need help finding a clutch (dkrex001)
Yup,,the 90-91 jdm s1 tranny needs this..
just go on ebay search "90 91 integra clutch"
Old Aug 15, 2006 | 06:40 AM
Default Re: need help finding a clutch (Mr.speaker)
ok kool i will have to do that then thanks for the help
Old Aug 15, 2006 | 06:48 AM
Loserkidwac's Avatar
Cool, good info i wasn't sure which clutch was needed for the s1 I did find it came in JDM 90-91 integras so I assumed the it was the same as the USDM and not like the 92-93...
For the OP, the 92-93 trannies along with the 94+ hydro trannies have the same number of splines on the input shaft but the thickness is different than the 90-91...you can mount a 92+ clutch disk on a 90-91 tranny but it may result in damaging th input shaft so make sure you get the correct clutch
Also for the pressure plate you need to match which flywheel you have, from what i have found 90-91 has a diffferent flywheel than 92+ so just make sure you get the correct clutch kit
Old Aug 15, 2006 | 06:51 AM
Default Re: need help finding a clutch (Loserkidwac)
Oh also a plug since they hook me up with a lot of good deals, go to http://www.lsdmotorsports.com and look for clutchs, i am running a stage 3 6 puck sprung clutch specialties clutch and it is awesome, i thin think they also have alot of big name clutchs too at really good prices and can help you find the correct clutch for what ever you plan to do to your car
Old Aug 15, 2006 | 02:29 PM
thanks ima check it out now
Honda_Fanatic
Aug 14, 2012 10:41 AM
jb0705
May 15, 2007 05:39 PM
90hatchie
Nov 10, 2004 12:04 PM
BseriesHatch
Nov 20, 2003 07:04 AM
NastyGsr94
Oct 8, 2003 03:12 PM
