K20 Swap Question
Old Aug 14, 2006 | 02:00 PM
Project_99Hatchback's Avatar
Default K20 Swap Question
I have a 99 civic dx and i want to put a 6 speed k20 into it. is this a good swap rather than say a ls/vtech also what do i need for throttle cable, rad, rad hoses, shifter linkage, wring harness anyone done the swap is it that difficult?
Old Aug 14, 2006 | 06:35 PM
civicstar's Avatar
Default Re: K20 Swap Question (Project_99Hatchback)
i say its going to cost alot more money then LS/vtec. To put a type S is around 4 grand and up + mounts in and type R is around 6000 and up + mounts. basically ur gonna need the normal things that a b series needs. a different type of radiator hose, the one off the rsx is fine, u need the k series shift linkage/cable, axles, custom mounts, ECU, a rsx stock ecu will not work because of the ignition chip that communicates with the ecu, so u gotta have it modified. and u need a new wiring harness for the motor and other things i cant remeber
Old Aug 14, 2006 | 08:26 PM
adip315's Avatar
Default Re: K20 Swap Question (civicstar)
http://www.k20a.org
They have good info on swapping k20's into eg's, ek's, etc.
Old Aug 14, 2006 | 08:39 PM
cool thx
lowerthanu
Aug 31, 2010 06:13 AM
jcalderon
Jul 2, 2007 09:43 AM
nemo_4321
Honda Civic (2001 - 2005)
10
Sep 4, 2006 03:44 PM
fullblownracing
Apr 1, 2004 05:18 AM
joeyitr309
Mar 26, 2002 04:20 PM
