valve adjustment gone wrong
Old Aug 14, 2006 | 12:21 PM
jkn1515's Avatar
Default valve adjustment gone wrong
over the weekend i was adjusting my valves on my ap1 and when i was retorquing one of the nuts, i over torqued it and sheared off the adjusting screw/stud. right now it's sitting almost flush with the rocker arm, and im thinking about backing the stud out and putting a new one in (i already ordered a new stud from honda). my question is - is it that simple? is there any pressure from the valve spring that's hitting the stud? is there anything else i need to look out for when i do this besides getting metal flakes in the motor from using ez out?
thanks for any advice
Old Aug 14, 2006 | 01:38 PM
thesmogman's Avatar
Default Re: valve adjustment gone wrong (jkn1515)
You shouldn't need an easyout. There shouldn't be any tension on it.
Just turn the crank until you see the rocker loose(Like when you were adjusting them) and get a sharp screwdriver, new or old one and sharpen it to a flat point and see if you can get it out that way first. Who knows it might work!
Old Aug 14, 2006 | 02:05 PM
jkn1515's Avatar
Default Re: valve adjustment gone wrong (thesmogman)
awesome! thanks for helping out. i was so frustrated with myself for doing something that dumb, from a job that's so easy.
Old Aug 14, 2006 | 03:16 PM
Dogginator's Avatar
Daisy... Daisy...
You will most likely need to pull the cam on that side to lift the rocker and remove the tappet adjusting screw from the bottom. Those screws are mushroomed.
Jota
Engine Machining & Assembly
13
Apr 10, 2016 03:02 AM
kornerk12
Nov 28, 2008 10:37 AM
Powered by VTEC
16
Jan 20, 2008 03:47 PM
SamC
Jan 24, 2003 08:52 AM
