What do i need to convert my non-vtec LS to a VTEC
hello
i did a search and did not find what i want
i have a b18b1 LS integra and want to make it a VTEC
if i swap the cylinder head with a vtec version will this be possible and how good is this particular block for turboing
what parts will i need to do this i am guessing a VTEC head
vtec switch inlet manifold ,manifold,different ecu and wiring
please can somone advise me
and has anyone done this =
Modified by 310BHPB16 at 12:52 PM 8/14/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 310BHPB16 »</TD></TR><TR><TD CLASS="quote">hello
Modified by 310BHPB16 at 12:47 PM 8/14/2006</TD></TR></TABLE>
putting on a vtec head on a ls block is called 'ls/vtec'
search harder next time
https://honda-tech.com/zerothread?id=1202212
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 310BHPB16 »</TD></TR><TR><TD CLASS="quote">why are ls/vtec so poor at making power
compared to a vtec GSR
i was looking at jeff evans dynos for built ls/vtec and they were similar to unbuild b18 turbos </TD></TR></TABLE>
ls/vtec is not poor at all for making power. far from it actually.
are you trying to compare a built all-motor ls/vtec to a turbo'd unbuilt b18b? if so, then of course the unbuilt turbo b18 will make more power. turbo just makes more power than all motor.
http://goldeneaglemfg.com
they make a kit that you need. even comes with the tap, to tap the head. but if you didnt already know what LS/VTEC is you prolly wanna leave that part to the pros
or buy a vtec block also!
