gsr swap - del sol dohc vtec shift linkage - need help!!
Old Aug 14, 2006 | 11:10 AM
spunky424's Avatar
Default gsr swap - del sol dohc vtec shift linkage - need help!!
I just swapped in a gsr into my del sol, and the del sol dohc vtec shift linkage does not fit. It is about 2-3 inches short of reaching the cabin of the car to where it is bolted onto. I got the linkage from a member on here who claims and swears he pulled it from a b16 del sol, but it just isn't long enough in my car with the gsr.
Has anyone with a b-series swap in their sol ran through this problem (if it truly is the right linkage)??
I really need to get my car running, can anyone help me out here? If someone can measure how the long the vtec shift linkage is, it would really help so I can compare with the one I have. thanks!
Old Aug 14, 2006 | 11:38 AM
THC07's Avatar
Default Re: gsr swap - del sol dohc vtec shift linkage - need help!! (spunky424)
wish i could help... if it turns out that you need a part from a LS integra 91 let me know.
Old Aug 14, 2006 | 05:52 PM
Orangedragone's Avatar
if i had to say, it's really not a dohc delsol linkage.
When doing the LS swap for my delsol--before i was told about the only linkage i could use, the integra linkage i had fell short also--just as you described.
Old Aug 14, 2006 | 06:48 PM
spunky424's Avatar
Default Re: gsr swap - del sol dohc vtec shift linkage - need help!! (Orangedragone)
anyone have the measurements for the del sol dohc linkage?
i'll have measurements of mine up tmw.
Old Aug 14, 2006 | 07:22 PM
instrument's Avatar
i have the dohc del sol linkage, and it is longer then the integra...i'll be getting rid of mine soon.
Old Aug 15, 2006 | 07:35 AM
spunky424's Avatar
Default Re: (instrument)
^ any chance you can measure the del sol linkage?
Old Aug 15, 2006 | 08:25 AM
evilsolb16's Avatar
i put a b16 in to my del sol ordered the shift linkage through honda so i know i got the right one. i didnt have any problems with it. when you look at the shift linkage does it kinda have a c-shape to it. if its the right one then it should line up .
redline870
Mar 23, 2011 09:30 AM
da_driver_15
Dec 25, 2010 12:23 PM
SRTDave
Nov 11, 2009 12:00 AM
teawoboba
Jun 3, 2004 06:44 AM
AzntaggeR
Dec 23, 2003 09:34 PM
