F22A4 head bolt thread repair
Old Aug 14, 2006 | 10:29 AM
runderwo's Avatar
Default F22A4 head bolt thread repair
Hey,
We fixed the top end on this motor and went to put it back together. One of the holes was real tough to turn a bolt in so we tapped it. Well, a lot of metal came out with the tap which made us real nervous. Sure enough, the threads gave out when bringing the bolt to final torque. The bolt now turns freely in the hole.
Now what? I called Honda parts asking them what helicoil to use and they didn't seem to know what I was talking about and recommended a new engine. A local machine shop couldn't find the bolt specs in his book either. I think I can fix it if I can get the correct helicoil. The only complication is, I don't know how I should tap the block for the helicoil since the threads are recessed into the block, is there anything special I have to worry about or should it be ok?
Old Aug 14, 2006 | 12:37 PM
khunt0012's Avatar
Meat Robot Invisible
Default Re: F22A4 head bolt thread repair (runderwo)
Only real chance I see of this being saved is a heli-coil. Is it any of these bolts?:
Old Aug 14, 2006 | 02:29 PM
runderwo's Avatar
Default Re: F22A4 head bolt thread repair (khunt0012)
Yeah, it's the #12 bolt in that pic, and it's the one that is to the left of the #2 exhaust port.
Old Aug 15, 2006 | 09:10 AM
runderwo's Avatar
So is there any way to find out the specs on that bolt?
Old Aug 15, 2006 | 12:07 PM
runderwo's Avatar
I emailed Time-sert to see if they knew the right one, we'll see.
Old Aug 15, 2006 | 01:40 PM
Eddiebx's Avatar
do u not have the bolt anymore? u can just measure the bolt size adn pitch off the bolt.
Old Aug 16, 2006 | 07:43 AM
runderwo's Avatar
Default Re: (Eddiebx)
The project is 100 miles away from me at the moment.
Old Aug 22, 2006 | 11:40 AM
runderwo's Avatar
Default Re: (runderwo)
Not a Honda dealer but Timesert finally got back to me. The bolt is M12x1.5 according to them. They claim that the Honda Odyssey kit should work. What do you think?
http://www.timesert.com/html/honda.html
DeeEx Rex
10
Jul 29, 2010 11:02 AM
sh!ft
Dec 20, 2009 05:02 PM
Cashieboi
Oct 9, 2006 08:17 PM
spidermancivic
Oct 3, 2006 09:41 PM
SKDRCR
Jul 27, 2005 09:01 AM
