what causes a fuel tank to rust?
Old Aug 14, 2006 | 09:47 AM
90civichbsi's Avatar
Default what causes a fuel tank to rust?
I bought an std shell for $200 and swaped in a b16, once i got it in i realized the fuel pump wasnt working and i dropped the tank. to my suprise i pulled out the pump and it was black and brown from rust and so was the inside of the tank. the fuel i drained came out yellow with rust residue in it.
this shell has been sitting for a few years think it could jsut be moisture buildup? the rust just seems too bad for it to be that though. just curious
Old Aug 14, 2006 | 09:54 AM
crxnj's Avatar
Default Re: what causes a fuel tank to rust? (90civichbsi)
yeah when the gas just sits it gets water inside, and you know what sitting water causes....There are additives to put in when letting a car sit,but some people dont know or dont care..
maybe you can just clean it out ,,then put in some fresh gas wit some seafoam and it will be ok...not sure
Old Aug 14, 2006 | 10:41 AM
crx_88_si's Avatar
rust has started, get a new tank. shouldnt be too much since you can do the work yourself from the sounds of it.
Old Aug 14, 2006 | 10:42 AM
ludesrv's Avatar
Fuel tanks are less then 200$ brand new with strap. Rubberised undercoating for the outside and you should be good.
Old Aug 14, 2006 | 10:51 AM
Default Re: (ludesrv)
yeah i just picked up a used one from the junk yard for $80 rust free gonna put it in tonight and hope the swap starts
91cb7h23
Feb 10, 2013 04:13 PM
uberEFtuner
May 23, 2010 10:59 AM
KarmaJosh
Feb 23, 2010 07:47 AM
kaoss_11
11
Dec 9, 2004 08:29 PM
sysconx
Jun 26, 2003 02:28 PM
