tranny clicks only in reverse
Old Aug 14, 2006 | 09:13 AM
ek4_b16a's Avatar
Default tranny clicks only in reverse
hi all! after my swap...i noticed that my speedometer doesn't work anymore. i'm thinking that it is cause of the tranny.
when i am in reverse, it clicks...and that is the only time it'll ever click. any idea on what is causing that clicking noise? is my reverse gear busted somewhere?
the car still reverses fine, but clicks..and it is an annoying clicking.
any help will do...
thanks in advance!!
Old Aug 15, 2006 | 02:00 PM
ek4_b16a's Avatar
Default Re: tranny clicks only in reverse (ek4_b16a)
i guess no one knows anything of this then, correct?!
thanks!
Old Aug 15, 2006 | 03:04 PM
jdmeg9's Avatar
some lsd's click in reverse. what tranny is it?
Old Sep 1, 2006 | 02:06 PM
ek4_b16a's Avatar
the tranny is a y21. how do you check to see if it has lsd? can you see it or you have to take it apart?
Old Sep 1, 2006 | 02:07 PM
krisjk2's Avatar
it clicks when you shift it in once? or you shift it into reverse and it's a constant click?
Old Sep 1, 2006 | 03:28 PM
jdmeg9's Avatar
pop out the axles and see if you can see through the tranny
Old Sep 1, 2006 | 03:36 PM
dthug's Avatar
Default Re: tranny clicks only in reverse (jdmeg9)
i think all trannies do that dont they
i know if you press in the clutch go to forth, still have the clutch in then go to reverse it doens't do that click sound
Old Sep 10, 2006 | 05:26 PM
ek4_b16a's Avatar
Default Re: tranny clicks only in reverse (dthug)
constant clicking in reverse
it shouldn't click at all when you are in reverse...at all....
Old Sep 10, 2006 | 05:58 PM
loclowd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek4_b16a &raquo;</TD></TR><TR><TD CLASS="quote">constant clicking in reverse
You are right, it sounds abnormal. Subscribed, because I've never heard of this happening
Old Sep 10, 2006 | 07:09 PM
Jhonny Ricer's Avatar
Default Re: tranny clicks only in reverse (loclowd)
Check your fluids mine has a slight click if you depress the clutch while it isnt in gear at idle sitting still
E9CiViC1F
Aug 25, 2009 02:55 PM
Scotty Dosent Know
Dec 9, 2005 05:05 AM
LostSolVTEC
Mar 8, 2004 10:23 AM
OldSchoolCrxSiR
Jun 8, 2002 12:06 PM
