2 questions
Old Aug 14, 2006 | 05:27 AM
NathanielH's Avatar
Default 2 questions
Hey guys, i have a couple quick questions.
1) im swapping a b16 into my eg hatch (CX), can i use the stock throttle cable?
2) i dont have a "flywheel inspection cover", i beilve thats what it is called. is it an absolute necesity to have on there? i have been told no... but im not so sure. i would think that it would be. if it is necisary, would one off of a DA integra with the cable trans work? or a d seris hydro?
thanks in advance
Old Aug 14, 2006 | 06:17 PM
NathanielH's Avatar
Default Re: 2 questions (NathanielH)
Old Aug 15, 2006 | 05:04 AM
NathanielH's Avatar
no one knows?
Old Aug 15, 2006 | 05:04 PM
NathanielH's Avatar
come on, i know im not the "pioneer" of the b16 swap.
Old Aug 15, 2006 | 10:29 PM
91SiZ6's Avatar
^^Exactly. The information is everywhere, dude.
Not a good idea to leave your flywheel/clutch exposed to the elements and road debris.
Old Aug 16, 2006 | 05:20 AM
NathanielH's Avatar
Default Re: (91SiZ6)
i know there is info everywhere, but i havent seen anthing about wich throttle cable to use, trust me, ive looked. I also had the same idea about that flywheel cover, wich is why i asked if i could use one from a d-series, because i could just swap my current one.
Old Aug 16, 2006 | 03:41 PM
91SiZ6's Avatar
If I remember correctly, you're supposed to swap the throttle linkage so you can use your stock cable.
And I'm pretty sure that everything D is too small for B, though the DA one should work without any problems.
Old Aug 16, 2006 | 03:55 PM
NathanielH's Avatar
cool thanks.
Old Aug 16, 2006 | 03:57 PM
unknown0001's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NathanielH &raquo;</TD></TR><TR><TD CLASS="quote">Hey guys, i have a couple quick questions.
1) im swapping a b16 into my eg hatch (CX), can i use the stock throttle cable?</TD></TR></TABLE>
From what I read and have seen myself...no the stock throttle cable will not work...it's too short unless you make yourself a bracket(PITA)
Your best bet is to hop over to the auto wreckers and get a 90-00 integra throttle cable and it will work fine
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NathanielH &raquo;</TD></TR><TR><TD CLASS="quote">2) i don't have a "flywheel inspection cover", i beilve thats what it is called. is it an absolute necesity to have on there? i have been told no... but im not so sure. i would think that it would be. if it is necisary, would one off of a DA integra with the cable trans work? or a d seris hydro?
thanks in advance</TD></TR></TABLE>
I would recommend putting on the flywheel cover back on because it will prevent from rocks/dirt/rain to getting by your transmission spline, clutch and flywheel.
About the DA integra one working on a d-series? I don't think it would as it's a b-series engine and with the blocks they seem to be of a larger size, so unless you re-drill the holes to accommodate where the bolts go on the d-series then direct bolt-on will not work
Old Aug 16, 2006 | 04:05 PM
NathanielH's Avatar
Default Re: 2 questions (Mr.RHTuner)
thanks for the info Mr.RHTuner. too bad all the junkyards i know of dont have any integras that havent been molested for everylast part. guess ill have to order it through honda, and im sure it will take a week for them to get. i worded my second question a little funny, but what i was asking was if the inspection cover off of my current trans (a z6 trans, mated to the anemic b8 motor) would work on my b16 trans. or if one off of a old DA integra would work (because i though i knew a kid who would have it). but i think you answered my question, in that it wont work.
Old Aug 16, 2006 | 04:07 PM
NathanielH's Avatar
oh yeah, one more question. ive looked for diagrams and directions for this, but have found none. wich wires do i need to splice into, or wich wires do i need to run to the ecu to switch from the 1 wire to 4 wire heated o2?
Old Aug 16, 2006 | 04:53 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NathanielH &raquo;</TD></TR><TR><TD CLASS="quote">but what i was asking was if the inspection cover off of my current trans (a z6 trans, mated to the anemic b8 motor) would work on my b16 trans. or if one off of a old DA integra would work (because i though i knew a kid who would have it). but i think you answered my question, in that it wont work. </TD></TR></TABLE>
The DA integra cover will more then likely fit on the b16 as opposed to the d-series one as the size of the bolt hole placement might have been closer on the smaller d-series engine..
Your best bet would be to get the DA integra flywheel cover and install that onto your b16
Old Aug 16, 2006 | 10:13 PM
91SiZ6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NathanielH &raquo;</TD></TR><TR><TD CLASS="quote">oh yeah, one more question. ive looked for diagrams and directions for this, but have found none. wich wires do i need to splice into, or wich wires do i need to run to the ecu to switch from the 1 wire to 4 wire heated o2?</TD></TR></TABLE>
Have you tried tracing the wires to their ECU pin-outs with a Z6 wiring diagram?
Old Aug 17, 2006 | 05:12 AM
NathanielH's Avatar
Default Re: 2 questions (91SiZ6)
thats a good idea, but i actually found a link that has the wires/pin outs listed. i do have another question though, do i have to run these wires through the connectors on the left shock tower, or can i just run wires straight the ecu connector?
Old Aug 17, 2006 | 11:39 AM
91SiZ6's Avatar
It's better to run them to the shock tower just for the extra flexibility and clean factor. It's not neccessary though.
Old Aug 17, 2006 | 03:43 PM
NathanielH's Avatar
cool, thanks for the info bro. damn, youve answered my questions in 2 threads now, you are no deemed my official tech-line. jk. thanks for the info though
Old Aug 17, 2006 | 05:02 PM
NathanielH's Avatar
Default Re: (NathanielH)
actually i now have ANOTHER question. im just full of them, arent I... if run the wires to the shock tower, are the wires at the shock tower connector already ran down through to the ecu connectors? and are there pins at the ecu connectors?
Your Name
May 5, 2009 11:44 AM
Sic_DA_Nine
Mar 27, 2007 04:39 PM
blazinsii
Dec 19, 2005 11:32 PM
s2000june
12
Aug 15, 2005 02:35 AM
crxh22project
11
Jan 27, 2005 08:29 PM
