knocking/running like sh*t!!! help!!!
ok, heres the deal..i bought a fully built sohc vtec race engine..i put it in my 93 del sol and hooked up everything correctly..im am running my stock injectors and stock fuel rail, regulator,pump...ok, after i started it for the first time it sorta made a ticking/knocking noise...but ive bee told that race engines make a minor ticking sound(from cam or something) but when i took it out for a test drive i noticed that this engine ran like ****...!! no pick up at all..and it just drove very rough..and aside from the ticking sound it was making a pinging sound also....so i drove it to a shop and they told me it was either the rods or rod bearings...but im not sure what it is....does a built engine have to run off larger fuel management? it cant run off stock? someone please help.......write me at myka7500@aol.com or im me ..thanks
It's always good to upgrade the fuel output when building an engine. Now, if it's required to use a new fuel system depends on what compression is used and etc.
It sounds like someone sold you a junk motor. I would look around for a new bottom end or start rebuilding the bottom end. Your crank could be badly damaged from the rods/rodbearings, so you might need to replace it.
did you check the ignition timing? a race engine makes some funny nosies, but usually quiets down when it warms up. if you have messed up bearings you will hear the clack-clack sound all the time and will rise in frequency with rpm. if you think its detonating did you check the fuel pressures? maybe its something like that?
nengx07
Jan 6, 2010 12:29 AM
hotimportcrx
Oct 2, 2005 04:13 PM
charjacq
Oct 17, 2002 06:19 PM
charjacq
Oct 17, 2002 01:59 PM
