crx overheat removing thermo
Old Aug 13, 2006 | 08:37 PM
Pnoyej6's Avatar
* B A N N E D *
Default crx overheat removing thermo
Hey guys my friend crx is overheating. Is it possible if we can just remove the thermostat with no problems and run no thermo. I was thinking no thermo will help engine run cooler which will keep coolant flowing continuously. How do you remove thermo on crx si? Just curious. Yes no fans work,but he doesnt want to invest since its beat up crx daily driven
Old Aug 13, 2006 | 09:10 PM
Pnoyej6's Avatar
* B A N N E D *
Default Re: crx overheat removing thermo (pnoytegn707)
its bone stock. Will it be safe to run with no thermostat?
Old Aug 13, 2006 | 09:21 PM
Max Kling's Avatar
It will take a long time to get up to temp if it even does. When does his car overheat? Im guessing at idle and stop and go since you said no fans work.
Old Aug 13, 2006 | 09:25 PM
Pnoyej6's Avatar
* B A N N E D *
Default Re: (Max Kling)
yea stop and go. He doesnt care about ther ex. piece of **** body. He just want to drive it daily cheap way. So i can run it with no thermostat. Its ok as long it stays cool all the time. How do i remove thermostat in crx? any pics?
Old Aug 13, 2006 | 09:59 PM
Mr_CRX's Avatar
Default Re: (pnoytegn707)
follow the bottom radiator hose up to where it meets teh block. remove the two bolts holding that housing on, and pull the thermostat out.
i stil don't recommend running no thermo though, but that's how you do it.
Old Aug 13, 2006 | 10:08 PM
Zaakro's Avatar
Default Re: (Mr_CRX)
dont forget to un hook the battery, there is a ground on the housing and you dont want to mess up anything
Old Aug 13, 2006 | 10:54 PM
Greasemonkeyracing007's Avatar
why not just rig up a quick switch to make the fans work when you flip this switch, and just turn it on when you drive and turn it off when you dont, i think its easier,and cleaner than getting that radiator fluid all on you
that stuff gets in your pores and you smell like it for awhile. it should be hard,
Old Aug 13, 2006 | 10:57 PM
meant to say it shouldnt be hard
Old Aug 14, 2006 | 12:03 PM
W O T's Avatar
Default Re: (Greasemonkeyracing007)
I removed mine liast night, just 2 10mm bolts (1 is HARD AS **** to get to though)
Only thing that sucks is the coolant going everywhere I suppose, but I run straight water anyways
Itll defientely cool him down more, alot of people just jump the fan with a paperclip to have it running all the time when the car is on
Old Aug 14, 2006 | 01:55 PM
thesmogman's Avatar
Default Re: (W O T)
Well, I just want to let you know that your computer is looking at temp so it can go into closed loop. Closed loop is when the computer is acting on it's readings from various sensors not just a basic programmed setting.
My suggestion is to either hardwire the fan or go to the junkyard and get one.
Depending on your driving it would be worth it to fix it because your gas mileage will suffer badly. And at todays prices you would make up for the cost of a junkyard fan. That is if the fan is actually bad.
Will you check the fan switch connection under the dizzy. It is a single wire going to a sensor in the head. Might be just that!
jeezyskillz
Nov 21, 2006 11:41 PM
tmihok
Nov 8, 2005 03:15 PM
crxhftosi
Jan 25, 2005 05:44 AM
ryanhejka
Sep 17, 2004 09:42 PM
