alrigth confused, andneed help NOW! obd2 -0bd1 jumper harness
Old Aug 13, 2006 | 06:58 PM
Naudlee's Avatar
Default alrigth confused, andneed help NOW! obd2 -0bd1 jumper harness
we'll thieves stole my ecu along w/jumper harness out of my 99 civic hatch. I need to buya new jumper harness and I'm nt sure whichone...
I know obd2b is 99-00 civic, but the motor in the car is a 99 integra type-r, and its engine harness was used. So which do I buy obd2a or obd2b jumper?
Old Aug 13, 2006 | 06:59 PM
Sleepy_Red_hatch's Avatar
Default Re: alrigth confused, andneed help NOW! obd2 -0bd1 jumper harness (Naudlee)
correct me if i'm wrong but integras used OBD2-a until 2001
Old Aug 13, 2006 | 07:00 PM
Naudlee's Avatar
yes, butI wasn't sure if the engine harness wen't into the cabin or what not where the ecu is plugged into. as in liek as far as that goes it still utilized the civics harness
Old Aug 13, 2006 | 07:07 PM
Naudlee's Avatar
I needa' order a new jumper harnes like now, so if anyone could clear this upforme, I'd appreciate it, thanks!
Old Aug 13, 2006 | 07:23 PM
Naudlee's Avatar
does the dash harness have the ecu plugs or the engine harness? I don't think the previous owner re-did the whoel dash harness aswell... so would this be obd2b?
Old Aug 13, 2006 | 07:50 PM
Naudlee's Avatar
anyone, I wanna' order this from xenocron before I go to bed
Old Aug 13, 2006 | 07:56 PM
Naudlee's Avatar
anyone?
Old Aug 13, 2006 | 08:06 PM
Naudlee's Avatar
some help me, 45 views and no help really, caman' please!
Old Aug 13, 2006 | 08:18 PM
Naudlee's Avatar
help please!
Old Aug 13, 2006 | 08:24 PM
Naudlee's Avatar
if anyhelp the cars runnign a GSR cluster too, idk. I don't wanna' end up buying an obd2a one when Ineed an obd2b one, vice versa...
Old Aug 13, 2006 | 08:31 PM
Naudlee's Avatar
ttt I really need a straight answer
Old Aug 13, 2006 | 08:40 PM
Naudlee's Avatar
ttt
Old Aug 13, 2006 | 08:45 PM
Naudlee's Avatar
come onnn!
Old Aug 13, 2006 | 08:48 PM
pvt_awol's Avatar
well, it's tough for anyone to answer, based on your info.
Here it is, plain and simple: if the dash harness is the stock '99 civic harness, then you'll need the OBD2b adapter.
Old Aug 13, 2006 | 08:55 PM
Naudlee's Avatar
alright,I have the papers on the swap, it just says ITR engine harness
would thismean the dash harness is still the stock obd2b one, see idk, the cars still at the garage anyways
Old Aug 13, 2006 | 09:03 PM
Naudlee's Avatar
I'ma go look at ittomorrow morningthenorder I guess, what do Ilook for to make sure I buy the right one?
Old Aug 13, 2006 | 09:17 PM
pvt_awol's Avatar
well, the ITR engine harness WILL plug into the stock civic harness.... so, if I was doing this swap at my shop, I wouldn't go to the trouble of changing out the dash harness. I'd bet solid money that the dash harness is still stock, and that you'll need the OBD2b adapter. (as far as the GSR cluster, it's still easier to swap out the teg plugs into the civic harness, then it is to swap out the harness.... so I still say that it's prolly the civic harness)
Old Aug 14, 2006 | 06:25 AM
Naudlee's Avatar
alright,t hats what I figured, Iknow I hadve a mess of wires where my ecu rested, all taped up as if they were uesed prior, but that doesn't help any. Are there any like tell tale signs that I'd know?
jaelynrei
13
Sep 15, 2014 10:53 AM
brandonEM1
Engine Management and Tuning
Nov 24, 2013 04:21 PM
just_dung
11
Jan 7, 2013 11:42 PM
CivCruise
Jun 29, 2009 07:49 PM
josh green
Jan 20, 2005 04:19 AM
